Old 09-27-2002, 05:00 PM
Motorsport-SVX's Avatar
Motorsport-SVX Motorsport-SVX is offline
check out www.planetsvx.com
Radio antenna question
Does the stock radio have a solder on or plug
in antenna ? will I need a kit to convert it with
my Alpine CD player...?
thanks....Dayle
My mom will forever live in me and
never be forgotten, one day Ill see her again
CLICK the LINK below to Visit the SVX Store:
http://www.planetsvx.com
http://www.motorsportwarehouse.com/svx/sig2.jpg
Cars in the garage:
92 Toyota Soarer Single Turbo JDM RHD
70 Boss 302 Mustang 39k original miles
97 SVX Lsi
92 Liquid Silver Murano-ized (1st of its kind)
71 Cougar Xr7 Conv 351c 4v 4spd
69 SS Camaro 350
71 Nissan RHD Fairlady Z
70 Stang Fastback
70 Amc AMX 390
71 240z
89 Conquest TSi w/ 5.0 v8 swap
84 Mustang GT Turbo conv
"good, if it bleeds, we can kill it ....."
Old 09-27-2002, 05:38 PM
Aredubjay's Avatar
Rat Fink Member ~:o)
Re: Radio antenna question
thanks....Dayle
The antenna unplugs from under the carpet on the driver's side of the tranny tunnel. They're just below where the console meets the carpet. There are two of them. The radio has two about a foot to foot and a half leads that are soldered, with a male plug on one side and a female on the other. When you replace your unit, you'll only need to use the one lead into the appropirate (I think female) lead that goes to the antenna, unless your Alpine unit uses diversity tuning, in which case, it will also have two leads.
Randy Johnson
Mike Davis -- at Reading VI
Old 09-27-2002, 05:58 PM
So Im a little confused, the plugs your talking from
the factory, will I be able to use the ones already there
or is it possible Ill need a conversion kit to go from
the soldered units to a antenna plug.?
Im a little retarded, so bare with me. Ill be pulling
it apart tomorrow......
thanks for the help.......
Cars in the garage:
97 SVX Lsi
69 SS Camaro 350
70 Stang Fastback
70 Amc AMX 390
71 240z
Old 09-28-2002, 06:23 AM
immortal_suby's Avatar
Thread Killah
There is one male plug coming out of the car, you plug that into the female hole in your new radio. You may have to pull up the carpet a bit to change the routing of the antenna wire so it is long enough to make it to your radio - or you could buy an extension for it. You will not need to solder anything.
There is another female plug coming from the car which is basically useless. I remember hearing it is for the glass antenna that tunes AM radio but unless your new radio has this capability you won't even plug it into anything.
Locker Link
2015 BRZ Limited 6MT
