Old 08-16-2012, 11:28 AM
Green1995SVX's Avatar
Re: need help ASAP :(
Originally Posted by kwren View Post
Sorry, but using a 1/2 inch drive for that job is borderline laughable.
Keith
What size drive would you suggest? I wasn't aware there was anything larger than that that was readily available.
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 08-16-2012, 11:58 AM
LastSVXintheChi's Avatar
LastSVXintheChi LastSVXintheChi is offline
Send a message via AIM to LastSVXintheChi
is the slot to hold the engine fairly obvious or am i gonna be searching?
does anyone have a picture by chance?
Jared
1992 dark teal SVX LS
Old 08-16-2012, 02:26 PM
For those rare occasions when nothing else will work, I have 3/4" drive ratchets and sockets. 17" ratchet, 24" breaker bar and sockets from 19 mm up to 50mm.
Available at HARBOR FREIGHT for less than $50.00.
i like the sure-grip sockets which grip the fasteners on the flat side so as not to round off the points. Transmits more torque.
Old 08-16-2012, 02:34 PM
kwren's Avatar
kwren kwren is offline
For those rare occasions when nothing else will work, I have 3/4" drive ratchets and sockets. 17" ratchet, breaker bar and sockets from 19 mm to 50mm
3/4 inch... Likewise... I have it as well.
I was simply trying to make a point about how tight that big old bolt needs to be. When you add the big old mauler, it works great! Pulling it "real hard" is a bit too light!
Big old mauler is easy but be sure you don't misdirect the swing to anything else!
I actually prefer the long box end wrench because the socket can more easily slip off as you hit it with the big old mauler!
Keith
Old 08-16-2012, 03:26 PM
Ok so im locktited and torqued to 120lbs so hopefuly we are all good...i replaced the pulley cus the key way was misshapened
Jared
Old 08-16-2012, 05:44 PM
Blue or green lock tight do not use RED . Blue is common and the green is harder to find. Green is a gap filler, blue is a semi hard and red is
" I don't want to ever take it off with out a torch "
Do what you want but think before ever using red. This is 38 years
Of experience talking.
You use loctite on the key, not on the bolt.
Old 08-16-2012, 06:55 PM
Did I mention anything about a bolt. Let me re read my post ...NOPE.
Old 08-16-2012, 07:14 PM
Uh oh too late.....
Jared
Old 08-16-2012, 07:20 PM
That's true but....
You don't ever want the key to move........
Old 08-16-2012, 08:58 PM
BUT AND IF are big little words. The key should never move. Blue would hold it. Still would take a real batting to get it out. Y not just JB weld it in.
Old 08-16-2012, 10:28 PM
trust me, when the keyway is damaged, it will move if you use anything but the strongest loctite.
JB weld is for plastic not to mention you have to be able to get the crank pulley and crank sprocket off if you ever want to do your crank seal, or remove/reseal the oil pump.
Old 08-17-2012, 10:42 AM
kwren's Avatar
Not to mention timing belt...
Keith
