Old 05-13-2012, 01:48 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Hub removal
I usually bring the housing assembly to Subaru to press out the Hub and bearings. This time I would like to do it myself. How do you press out the hub from the housing without crushing the back plate. Is there a special way to set it up on the press without damaging the other parts?
Subaru SVX for fun
Susuki SX4 for my older son
Ford Ranger for work
Old 05-13-2012, 02:06 PM
Re: Hub removal
While installed I use a slidehammer.
Old 05-13-2012, 02:16 PM
dannmarr's Avatar
I work for my SVX
Re: Hub removal
I don't have a slide hammer Has anyone used the press bench rather than a slide hammer? If so, how did you set it up?
Subaru SVX for fun
Old 05-17-2012, 02:50 PM
dannmarr's Avatar
I work for my SVX
Re: Hub removal
I brought the housing assembly to my mechanic. He was able to remove the hub without the press. I was very impressed by his method. It is hard to explain, so I'll take some picture with instructions the next chance I get.
Subaru SVX for fun
Old 05-22-2012, 08:09 AM
dannmarr's Avatar
I work for my SVX
Re: Hub removal
This is how my mechanic removed the rear hub from the housing. He took off the bolts that hold the back plate to the housing. This enabled him to slide the back plate far enough to grab the housing from the inner side with clamp. He set it up on a bench vise. He then slowly cranked the jaw clamp until the hub was pressed out. He did the same with the bearing.
Subaru SVX for fun
Old 05-25-2012, 02:19 PM
torxxx torxxx is offline
Re: Hub removal
they make a really neat tool called a hub tamer. I never used one til I started working at last shop I was at. Its like a mini press/slide hammer deal where u can do wheelbearings/hubs on the car
You may be able to rent one from a tool shop (they are pretty spendy to buy if you are just a backyard mechanic it takes about 10 bearing/hub jobs to equalize the cost)
92 Svx 4.44 swap 198k miles. Toyo Garit KX tires.. my Icetrack car
86 Lifted GL wagon well over 600k miles on the chassis
98 Outback 5 speed 6 inch lift, forester struts/springs 29" tires
Old 05-25-2012, 05:11 PM
processengr's Avatar
Re: Hub removal
When YT changed the bearings at my house, he used a hub tamer. Bearings are holding up nicely...Factory bearings, did not repack them.
Cheers! Gordon
1992 Ebony 251k 444 SOLD
1999 Silver SLK230 134k SOLD
1997 Green Outback 137k SOLD
2013 Honda Accord I4 SOLD
2015 Subaru Crosstrek 30k
2018 Tesla M3 30k
