Old 06-08-2010, 06:44 PM
Is it bad to hear a chirp from the front tires?
Just recently on a couple fast pull aways I have heard a slight chirp from the front tires, maybe I am driving it a little harder, but I am not really used to hearing it. It surprised me in fact. Could my AWD failing me or is it somewhat normal?
I also noticed that the air pressure in the tires was wrong, the fronts were 29 and rears were 33. I guess I need to check that after tire rotations. Could that have anything to do with it?
Old 06-08-2010, 07:26 PM
Re: Is it bad to hear a chirp from the front tires?
If the AWD is working OK ,you should not get any front wheel spin. Try it on grass, if it will spin the front wheels, the clutch is not working.
The TCU should always anticipate any drive load, based on throttle, gear, and speed, to apply the transfer clutch to prevent it.
Old 06-09-2010, 04:18 PM
Probably I'll just have it checked next time it is up on a lift.
Old 06-09-2010, 04:48 PM
It won't show up on a lift, there is no load. Just try a fast start on some grass or sand, the fronts should not spin.
Old 06-10-2010, 07:05 AM
All right I'll give that a try and report back. -First I need to keep an eye out for a suitable place to do that as I don't find myself driving on grass much.
Old 06-10-2010, 09:55 AM
Freeman's Avatar
Freeman Freeman is offline
Unregistered User
Maybe it's time for new tires?
Old 06-10-2010, 10:27 AM
Gamesy's Avatar
Gamesy Gamesy is offline
ur tranny's canned, lol hate to say it same thing happened to me.
i think the center diff failed so most power to the front.
then 4th gear went and now 3rd gear went. its fun spinning front wheels until the back ones finally get power.
sorry to say.
Old 06-10-2010, 10:54 AM
I'm thinking the transfer clutches are on their way out, or already sheared off, especially if you are not throwing a transmission code.
Old 06-10-2010, 11:00 AM
sorry to say.
Well we'll see. As you said, it does seem like I feel the rears kick in a few second behind the fronts.
I can't say I really care too much as I plan on doing a 4.44 upgrade eventually anyhow.
