Old 06-04-2010, 12:31 AM
thickasxthieves thickasxthieves is offline
Send a message via AIM to thickasxthieves
no start after installing ecutune stage 2 help please!
So bout a hour ago i wrapped up putting in ecutune stage 2 injectors and z32 maf. and now it wont start. fuel pump is reconnected. all the wires from injectors were attached to the new injectors/connectors in the order they were attached to the stock injectors. maf is wired up exactly right that i know for sure. car will crank and crank and crank and never catch. so my primary suspect is the injectors but....i dont know what to look for where to start im pretty sure theyre all wired up correctly.... i just dont know where to go from here. any insight? would be much apreciated. im leaving for the beach tomorrow(hopefully, if we can get the car to run). i just had to have the stage 2 before i went down. sigh.
94 Emerald LS w/ awd 4.44 swap 199xxx daily driver
Stage 2 ECUTune chip, 370cc injectors, ECUTune valve body and TCU, solid rubber motor mounts from a forester, outlaw phenolic spacers, COBBTuning lightweight blue crank pulley, Bontragerworks 22mm rear sway bar & endlinks, StrongFlex poly front sway bar bushings, Powergrid adjustable front sway bar endlinks, 17" MOMO CORSE RPM wheels w/ Toyo Proxes4 225/45, drilled/slotted rotors f/r, stainless lines, ceramic pads, Blue silicone radiator hoses, power mode switch, gold jdm hood badge, 20% tint all around, Hella optilux xtreme yellow fog bulbs
parts waiting to go on car: the rest of the strongflex polyurethane suspension bushing set
Old 06-04-2010, 02:11 AM
Re: no start after installing ecutune stage 2 help please!
You removed the little resistor thingy inside the ECU right?
Old 06-05-2010, 09:37 AM
immortal_suby's Avatar
Thread Killah
Recheck your stage 2 ECU chip installation and make sure the board is seated in there fully.
If nothing there, next step is to find out if it is gas or spark.
Locker Link
2015 BRZ Limited 6MT
Old 06-05-2010, 11:55 AM
+1 on that. When I put in my stage 1 chip it was not seated all the way and it did the same thing, a strong crank but would never catch.
