Old 05-12-2010, 10:38 AM
smokin_dodge smokin_dodge is offline
What part is this?
I got error codes 24 and 56 so to start off i decided to clean both idle air controller/bypass air controller and egr
well in process of removing the intake manifold i broke off tow vacuum nipples for a vacuum sensor or valve of somesort - problem is i have no clue what it is.
it is located in forward right corner if your facing the front of the engine - right behind where the ac compressor should go right under the intake manifold.
it has the numbers 3Y01 on the side and it looks like an emblem that says NOIC or NOK?
any help?
Old 05-12-2010, 12:56 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Re: What part is this?
That solenoid controls the actuation of the IRIS valve. The IRIS valve opens under high RPM to allow cross-intake airflow for higher power.
Old 05-12-2010, 01:26 PM
ok - well ive tried to find one and have had no luck. where can i get a new one?
Old 05-12-2010, 06:25 PM
michael's Avatar
michael michael is offline
What Potholes ???
http://www.subaruparts.com/cart/?pn=14774AA371
Wanted: Steering Wheel
Old 05-12-2010, 06:30 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
I get most of my stuff from subarugenuineparts.com.
I did not see a specific listing for that solenoid, but if I remember correctly it is nearly identical to the EGR solenoid which should work. Someone please correct me if im wrong.
Old 05-12-2010, 06:37 PM
Others have broken the same piece of that solenoid. Some have repaired it by gluing it back together with a two part epoxy.
Old 05-12-2010, 07:49 PM
SubaCraig's Avatar
SubaCraig SubaCraig is offline
I have one.....I saved it from an engine core after I sold the intake manifold.
you can have it for $20.
-craig
