Old 04-27-2010, 07:14 PM
Subie59's Avatar
Subie59 Subie59 is offline
94 SVX LSI Teal
Re: Slippage between 1st and 2nd gear
Ok, sounds easy enough. And if it is low-line pressure. what would the fix be?
94 SVX LSI
2001 LegacyGT (daughter's ride now)
2005 Legacy outback XT (wife's car)
all stock and likely staying that way for now
1981 Datsun 280zxturbo summer toy
Old 04-27-2010, 07:17 PM
Could be a blockage in the strainer in the pan of the box, or the box has worn to the point of replacing.
Old 04-27-2010, 07:22 PM
Subie59's Avatar
94 SVX LSI Teal
Ok, I fear it is the latter, but we will see....
94 SVX LSI
Old 04-27-2010, 07:28 PM
Originally Posted by oab_au View Post
If the band was slipping on the 1st to 2nd change, it would not just rev like it was in neutral, as it would still be in 1st gear, till the band comes on at a higher road speed.
So instead of changing at say 5600, it would go to say 6800 before the band griped to go to 2nd.
The above can only apply in the event that near full throttle is applied in anticipation of maximum acceleration. If slip is apparent and as a result of caution, excessive throttle is not applied, the transmission will remain slipping in second and this would indicate a possible band brake problem.
It has been made clear that something is slipping and this can be surely be relied on as a being well founded.
Old 04-27-2010, 08:07 PM
Verify by properly test the line pressure, using a gauge connected to the port provided for this purpose. Any reliable transmission shop should be able to carry out this standard test.
First things first and which do not require removal of the transmission.
Blocked external cooler or filter. Blocked main strainer. Solenoid "A" valve fault.
Blocked internal strainer/filter associated with the pilot valve. This calls for removal and separation of the valve body.
Old 04-27-2010, 08:24 PM
sowise sowise is offline
You said your fluid was good as far as level but how old is it? If you have a lot of miles, contaminated fluid, and/or overheated your fluid this could possibly affect your line pressures as well, something to do definitely when or if you take Trevors advice on the trans filter. Though if you drain it may as well drop the pan to inspect further.
Old 04-27-2010, 08:34 PM
Yes drop the pan, look for debris. In all of this it can be assumed that many dollars have been spent by many, due to proper diagnosis having not been carried out. The specialist with one hand on his pocket, will always have it that the transmission is of necessity stuffed.
Old 04-27-2010, 09:54 PM
Subie59's Avatar
94 SVX LSI Teal
Fluid was clean (replaced about 11/2 years ago) but i did replace the fluid again today just to see if it makes a difference. Seems to have made no difference. Did not drop the pan but it will be the next job I get done after checking the pressure. Will let everyone know the outcome.
94 SVX LSI
Old 04-28-2010, 08:17 AM
Subie59's Avatar
94 SVX LSI Teal
Ok just thinking: if the tranny is toast, how long or how many kms. could I put on it living with this slipping between 1st and 2nd before it gets undrivable. Right now it's really no problem. Drives perfectly once it gets into 2nd. And I don't drive the car much as it is....
Anyone living with this problem....
94 SVX LSI
Old 04-28-2010, 09:19 AM
Freeman's Avatar
Freeman Freeman is offline
Unregistered User
That'd be me. I've been driving her for about six months or more like this, no real complications. I've learned when to press for gas and when to let off. I'm going to get my brake band adjusted when I get my exhaust work done by OT though.
Old 04-28-2010, 10:06 AM
Subie59's Avatar
94 SVX LSI Teal
ok well that is interesting considering I'm probably taking the car off the road for six months to drive my Z for the summer. hmmm I could put off this major repair for at least a year or two....
unplugged the line pressure module (behind the battery) Seemed to make no difference whatsoever.
94 SVX LSI
Old 04-28-2010, 10:30 AM
Subie59's Avatar
94 SVX LSI Teal
Freeman: Is it your daily driver and how many miles do you put on a week???
94 SVX LSI
Old 04-28-2010, 02:37 PM
Freeman's Avatar
Unregistered User
Yes it's my dd and I drive it to and from work 5 or 6 days a week plus I drive around for fun. No clue how many miles.
Old 04-28-2010, 04:54 PM
[QUOTE=Subie59;644934]ok well that is interesting considering I'm probably taking the car off the road for six months to drive my Z for the summer. hmmm I could put off this major repair for at least a year or two....
unplugged the line pressure module (behind the battery) Seemed to make no difference whatsoever.[/QUOTE]
When you say "no difference whatsoever" Do you mean, the problem of shifting was the same?
Was there no difference in the hardness of the shift, with the resistor unplugged?
Old 04-28-2010, 07:44 PM
[QUOTE=oab_au;644967]
From the dictonary on my Mac. --- whatsoever, adjective. at all, of any kind, whatever, in the least, ' in any way, shape or form.'
