OEM EG33 engine reseal kit
I know there have been discussions/arguments on here that I have seen a few times about what is and is not included in the OEM engine reseal kit for the SVX, mainly pertaining to the 20 valve cover "washer" gaskets. Many have said/thought that these are not included when in fact they are. My point of this thread is just simply to clarify exactly what is and what is not in this kit. I can type in all part numbers included and scan the printout that I have when I get a chance probably after the weekend. If anyone is curious about anything before I get this posted, they can ask on here and I will get back as soon as possible.
-Nate Also, if the mods think that this is pointless, then they can go ahead and delete this, doesn't matter to me |
Re: OEM EG33 engine reseal kit
Mine contained all 20 valve cover bolt gaskets. It did not, however, come with the half moon seals that go at the rear of the heads (P/N 11051AA070, 4 req'd). I also do not believe it included the water pump gasket or thermostat gasket (P/N 21236AA010 and 21114AA051).
Whered you get it Nate? I need to do mine bad!!
Is there anything else that I maybe should get other than the 4 half moon seals (are these possibly meant to be reused? just curious, that's all) ? I am getting all of these parts for a forum member in Australia as the parts there cost so much. And I got them from 1stsubaruparts.com. $235.72 and if that's all you bought, it's 10% shipping so $23.58 shipping on just this. Also, ordered a bunch of other parts(some that needed ordering in) and total time from placing it to it arriving at my doorstep was 16 days. From when they sent the email saying it was shipped, just 2 days from WA to WI. Shipped Mon, got it Wed evening. Last edited by 1986nate; 12-31-2009 at 12:39 AM. |
Does anyone know the link to the valve cover gasket how-to ??
I got my kit but I haven't had time to look through it much, does it come with valve seals or other head related things like that?
and as noted previously in this thread, it does not come with the half moon seals for the heads... Last edited by 1986nate; 01-04-2010 at 12:17 PM. |
YT ordered a complete seal kit for me when he rebuilt my engine.
It came with the valve seals and head gaskets. He gave me credit for the head gaskets since I was using the Cometic ones. .
I'm going to be doing a reseal myself I just ordered valve cover gaskets and washers, crank seal, cam seals, but not head gaskets... do the head gaskets have to be done or can i reuse the old ones or will head gaskets not even come into play. please help a noob
94 Emerald LS w/ awd 4.44 swap 199xxx daily driver Stage 2 ECUTune chip, 370cc injectors, ECUTune valve body and TCU, solid rubber motor mounts from a forester, outlaw phenolic spacers, COBBTuning lightweight blue crank pulley, Bontragerworks 22mm rear sway bar & endlinks, StrongFlex poly front sway bar bushings, Powergrid adjustable front sway bar endlinks, 17" MOMO CORSE RPM wheels w/ Toyo Proxes4 225/45, drilled/slotted rotors f/r, stainless lines, ceramic pads, Blue silicone radiator hoses, power mode switch, gold jdm hood badge, 20% tint all around, Hella optilux xtreme yellow fog bulbs parts waiting to go on car: the rest of the strongflex polyurethane suspension bushing set |
New HG's come with the reseal kit anyway, so use them. I GUARANTEE that you will never be able to reuse a head gasket that is 16 years old and 175,000 miles of use. The P/N for the gasket and reseal kit is 10105AA060 .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 02-02-2010 at 11:53 AM. |
k i guess ill just order some up then. and no i wasnt planning on pulling the engine, unless its impossible to do all this without pullin it.
The vast majority of the rubber seals (valve covers, cam, front main) can be replaced with the engine in the car. To replace the rear main seal you must pull either the tranny or the engine. If you're going to be pulling the motor do the head gaskets. It's basically impossible to do them in the car, and the SVX is a relatively easy vehicle to yank the motor out of.
reseal kit arrived today
thankyou nate |
Ill be finally doing my valve cover gaskets in about a week, and reading this thread confirmed that they want WAY too much for the seals for the mounting bolts.
My question is: Can somebody tell me the approximate dimensions (diameter, center hole diameter, thickness) so that I can try to find them from some other source than Chaplins Subaru/1stSubaruParts/dealer etc etc. I may be able to source them from the local parts or hardware stores. This of course, is if they aren't too form fitted to be possibly substituted |
