Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Engine Management
Old 07-09-2009, 12:38 PM
poweredx2 poweredx2 is offline
Plasma Booster
I was wondering would a svx benefit from this ignition voltage booster basically.A company called igniton solutions has a product that splices one wire to each voltage wire on each coil pack and ups the voltage,they say you get crisper throttle response more torque and a little hp if your car is running rich,which does make sense because its burning unburnt fuel.Thinking about getting one next week its only 275 dollars,It has been dyno tested on cars with simliar coil on plug as the svx does.Any input
Old 07-09-2009, 01:16 PM
Wikedjuggalo's Avatar
Rebuilding
Re: Plasma Booster
I was under the impression we had enough going to them but if not this could prove interesting.
Old 07-09-2009, 02:13 PM
Re: Plasma Booster
That may be correct,but our cars are detuned our cars from the factory.I am impressed by how svx owners can get gains from a car that most companys now still won't touch.
Old 07-09-2009, 04:22 PM
longassname's Avatar
Just some dude.
Re: Plasma Booster
I haven't heard of this system but it sounds like another company's version of the msd box. The MSD box for coil on plugs is supposed to work well.
Old 07-09-2009, 07:19 PM
Re: Plasma Booster
Got a link to that Walter?
Old 07-09-2009, 08:11 PM
Re: Plasma Booster
A simple click on "Google" is all that is required to disclose heaps of information which turns out to be quite interesting.
Old 07-10-2009, 03:25 AM
Phil Hill Phil Hill is offline
Re: Plasma Booster
You wanna qualify that statement ?? I'm not sure that's strictly correct, or it would be easy-peasy to get another 20whp from the "usual go-faster" mods.
Phil.
Only the depth varies..............
Old 07-10-2009, 08:07 PM
Re: Plasma Booster
A decent intake, ecutune stage1v5 and some minor exhaust work,underdrive pulley,thats a easy 20hp.Add some custom made intake manifold spacers.I'm just indicating how 20 hp is available.Thats just engine mods,you have tranny mods such as upgraded TCUs,valve bodies for quicker shifts,QC shift kit.
Old 07-10-2009, 08:13 PM
Re: Plasma Booster
Check out Spark Boosters and Ignitions.
Old 07-11-2009, 09:11 AM
STeeL25T STeeL25T is offline
Soon to own a fuctional SVX
Send a message via AIM to STeeL25T
Re: Plasma Booster
I don't know if that's actually 20 hp or if its easy, thats a few hundred bucks in parts including a computer reprogramming. If you want to talk about easy horsepower and being detuned, I'd think of BPU on Supras.
Old 07-11-2009, 08:26 PM
Re: Plasma Booster
All the parts mention or available now, the chip alone gave my car a noticeable increase and at least 12-15whp.
Old 07-11-2009, 10:06 PM
Re: Plasma Booster
Im sorry to say this, I am a huge fan of power gains. But since when did 12whp become a noticeable increase?? Your HP and TQ will vary that much dependent upon air quality and density and I bet you have never noticed.
Old 07-13-2009, 03:40 AM
Re: Plasma Booster
My point exactly. It's simply the laws of diminishing returns. The SVX engine is at it's pinicle of development for it's era. 11:1 compression, 4 valve per cylinder, variable volume inlet system, sequential ignition and injection, knock and O2 adapting ECU......... it's a peach of an engine !!
The areas where performance improvement *could* be gained are from increased cam timing as from memory the cams have plenty of lift and fast ramps but the timing is pretty "soft", a porting job on the heads, some tuned length exhaust manifolds matched to both compression and cam timing, a carefully designed free-flow exhaust system and a remap to take advantage of these changes. None of these are, in reality, particularly cheap, nor "DIY-able".
Yes you can build your own exhaust, but some who have tried have found that simply removing or replacing a silencer/resonator doesn't yield the results they expected, in fact in some (most ??) cases the results have been negative in every sense.
You could grind your own heads but without a flow-bench how do you know if you've improved anything ?? Bigger isn't necessarily better !!
You could (and some have) specify your own cams, but they won't be cheap as there simply isn't the market to take advantage of the enconomies of scale of a decent production run, unlike for an Imprezza. And it's not all more pie, you might find that chasing that extra 20hp at the top end completely ruines the torque curve low down.
Subaru themselves have made some improvements to the performance of their H6 family by introducing variable cam timing and further improvements to electronic control, but that's simply changing the way you slice the pie, not necessarily increasing the amount of pie !!
As Tom says even a 20 "at the wheel" hp increase on an engine which subjectively puts 170 out as standard is only a little over 10%, and will not be that noticable.
You spends your money and takes your choice of course, and little mods here and there will, if correctly designed and applied, make little improvements which do all add up, but this whole idea that a free-flow air filter, a remap and some magnaflow silencers make an "easy 20hp" on an 1990's engine is laughable. Sorry to be so pointed, believe me it's nothing personal against you, just a general comment on the so-called "bolt-on tuning" world.
Phil.
Old 07-13-2009, 04:11 AM
Re: Plasma Booster
My car hasn't been on a dyno in a while back,but doing some personal tests where my svx needed a car in the quarter against a 95 impala ss,after the chip install the svx walks all over the ss.Also if you can't feel 12-15 whp which is maybe close to 20 at the crank on a fwd something is wrong.Tom you sell a intake that made about 20hp and people who have it say it was noticeable.Last what fwd car with 230hp only put out 170whp.My point is that you will notice your gains quicker with a fwd car which I should have mention at the start,my mistake.
Old 07-13-2009, 04:49 AM
Re: Plasma Booster
I laugh at people who say thet can feel a diffference. Through an auto you will not... EVER feel the difference. Thats why you go to a track to monitor changes or go to a dyno. Because the placibo effect has got the car enthusiast world by the balls.
