Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Engine Management
Old 06-05-2009, 07:38 PM
Jason S. Jason S. is offline
95 SVX ECU and trans Pinout
Does anyone have a pinout for the ECU and Trans ECU? I am having a hard time locating them.
Old 06-05-2009, 11:47 PM
Re: 95 SVX ECU and trans Pinout
behind driver's side kick panel. Remove the small piece that just snaps in there.
Old 06-06-2009, 03:06 PM
I know where they are, I need the pinout from the shop manual for what pins are what functions.
Old 06-07-2009, 01:26 AM
Boxersix's Avatar
Boxersix Boxersix is offline
Porsche Autofanatiker
I used this document for the PCM when I thinned out my harness to go in the WRX
http://serial.cc/pdfs/J___PIN_VOLTAGE_CHARTS.pdf
TCU not sure...
Old 06-07-2009, 12:03 PM
TCU not sure...
Thanks! I'm guessing the 95 is basically the same as the 92. Now I just need the trans controller!
Old 06-11-2009, 10:03 PM
No one has a pinout for the autotrans controller? Pretty please!
Old 06-12-2009, 06:12 AM
Hi Jason
I have posted up US trans wiring jpegs in the following folder:
http://www.subaru-svx.net/photopost/showgallery.php?cat=621&ppuser=66
I hope this will provide what you need. There is one proviso to watch out for; these are scanned from a '92 WSM. If your '95 car is wired OBD11 there will be differences in wire colours and other differences in the OBD connector arrangements.
The changes are not too radical I think, but I have not studied how much different the wire colours are in the OBD11 cars, it has no relevance for us over here.
Trust this will help.
Old 06-12-2009, 08:35 AM
Hi Jason
Thanks! The SVX Guys seem to be VERY helpful. This is my 2nd SVX (the first one stayed stock). The car is in getting repainted right now, when it gets out, it's getting the full treatment. Turbocharger, and a ProEFI computer to run everything! I'm not shooting for the moon with this car (I've had several single digit turbo cars), just want a fun street car!
Old 06-12-2009, 08:41 AM
Well keep us posted on your progress.
We love to hear what owners are improving and changing on their cars. Best of luck with the work.
Old 06-12-2009, 10:58 AM
Thanks! Will do. When I get it back from paint, i'll post some pics!
Old 07-15-2009, 01:05 PM
Well, got the car back from paint! Incredible work! No Orange Peel...looks like a show paint job! Need to get the windows tinted next, and find some nice wheels! The ProEFI is going in today, should have it running later this afternoon. I'll keep you posted and post some pictures if I get a chance later today.
Old 07-15-2009, 03:26 PM
That's good news Jason.
It will be good to see your pics, a good paint job is worth doing right.
Old 07-15-2009, 04:51 PM
be aware of the errors in the FSM about the ignition wiring if you plan on using the stock ignition. I will try and find the corrections I had found when working on getting my Hydra running
Old 07-15-2009, 04:55 PM
I did take note of a couple typos in the Factory Service manuals though for anyone who may need them in the future. The pins for the coils are wrong which is what was giving me such a hard time. And since the igniter doesn't just pass the current, I couldn't trace them with a simple test of continuity. So I had to do it the hard way on at a time.
Coil-ECU connector-Pin
1- b62- 10
2- b62- 8
3- b62- 9
4- b62- 7
5- b62- 21
6- b62- 16
Hope this makes sense
Old 07-15-2009, 08:02 PM
LOL! I wish I would have seen that post about 4 hours ago! I found that issue, got it sorted out. Car fired right up and came to a perfect Idle! Drove it around the block.... seat of the pants would suggest some instant improvement on the low end. It is still untuned with just the base map. I will try to get to the dyno by the end of the week for a back to back dyno comparison. The car is currently 100% stock, so we'll see what just the computer gets me. Then I'll start working on getting the turbo installed, but that might be a while.....we'll see. I might try an exhaust next, but some of that will be counter productive with the turbo install.
Thanks for all the help guys! My friends think I am crazy for playing with this car considering the other cars I have, but when you have owned one...you know how nice they can be!
