Old 01-10-2009, 07:47 AM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Strange sound
While driving up hill I feel a stuttering, thumping, choking kind of sound. This happens only when I excellerate quickly up hill. This does't happen from a stand still, it happens when I let go of the gas to slow down, then press the gas to excellerate. The speed or the RPMs dont change while I feel it. If I press the gas slowly, it's smooth. Could it be the regular gas I've been using? Dirty injectors? Anyone had this experience?
Old 01-10-2009, 07:34 PM
Re: Strange sound
Putting regular gas can cause the ECU to retard the timing but wouldn't think it would be that bad...Also how many miles as possibly could be due to a cat converter going bad... but again that would probably do it from stand still as well...
Old 01-11-2009, 08:34 AM
dannmarr's Avatar
I work for my SVX
Re: Strange sound
I just hit 190K. The converter is about 2 years old. I'll check my codes.
Old 01-12-2009, 01:08 AM
log1call log1call is offline
Re: Strange sound
Sounds like the symptoms, "I feel a stuttering, thumping, choking kind of sound", should lead to it really. Wish I could drive/hear/feel it.
A miss doesn't cause those symptoms, nor does a fuel blockage really... well not unless they are really bad missing or fuel blockages. Have you done a tune up? Plugs, air and fuel filter?
Old 01-12-2009, 01:39 AM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Re: Strange sound
Sounds actually like misfire or preignition. You ARE using 91 octane right??
Old 01-12-2009, 12:55 PM
Re: Strange sound
nope, he said he's using regular...
Old 01-12-2009, 02:27 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Re: Strange sound
Ahhh well priority one should be fill up with 91 octane and see if it goes away.... sometimes knock sensors dont work and wont retard the timing, resulting in the detonation you may be hearing. Yikes using regular 87 in a SVX is borderline criminal !!
Old 01-24-2009, 11:54 AM
dannmarr's Avatar
I work for my SVX
Re: Strange sound
I filled up with Premium and the noise went away. I guess that's what 'knocking' sounds and feels like. Thanks for the inputs.
Old 01-25-2009, 08:01 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Re: Strange sound
Splendid Hopefully this knocking business did not go on too long. Your knock sensor must be dead, it should have given a signal to the ecu to retard timing. Shouldnt be a prob now just keep the 91 proof flowing.
