Old 06-27-2002, 09:28 AM
EverclearAtMSU
would this hurt my svx
I've heard a lot of things about pulling the resistor. And I want to do it, but I dont want it to shift hard all the time, every now and then I would like to have the nice smooth shift. So I was thinking putting a switch in, up the resistor is in place; down, it's bi passed. I remember someone saying that the computer is going to have to get used to it. So if i was turning it on and off, would that cause my car to have issues?
Old 06-27-2002, 12:20 PM
museumquality
Talking
you may need to de-frag your mainboard often and perhaps if problems - find yourself reformating the main computer as well. (kd)
i asked a couple since my last post on this subject and though with out complete knowledge on this, they recommended not to do this. it could cause problems to the system as the computer was not designed to do so. remember each time you pull the resistor you will need to run the car for a few minutes, then shut down and restart for the computer to properly dial in this new configuration.
i recommend removing resistor permanently, and getting used to the "sport" setting as we call it. if you have decided to do this the reason may be because you seek performance vs pleasant shifts. you just need to decide which is more important to you and make your move.
Old 06-27-2002, 01:41 PM
scoochv scoochv is offline
i pulled my resistor yesterday, and while it's very subtle, there is indeed a difference.. it's not as not-smooth as one would think, but the difference is there.
i notice "auto-shifting" from 2 to 3, there isn't as big a lag as there used to be.
Old 06-28-2002, 03:22 PM
gcookaustin
Is there maybe a way to put in a "different" resistor, so that maybe it's not too hard and not too smooth? I'm not sure how the system is set up. It might blow something up; I don't know.
Old 06-28-2002, 03:38 PM
museumquality
when you say "it" may blow something up. what "it" are you refering to?
no you can not put another resistor in place. unless you are a subaru tech with access to all specs (tolerances) on whats required. and have additional knowledge in electronics, and are willing to experiment with different tolerances and power ratings.
i was told by a very reputable source to pull the resistor, do so by trial, if you feel that its performing more harm than good, then keep the stock connection.
track runners, nitrous shots, turbos, and hard drivers. you what to keep that trans as cool as possible. pulling the resistor is #1 in doing so.
Old 06-28-2002, 04:59 PM
gcookaustin
Well, by "it" I mean if you plug in a different resistor and you hear a large "boom" and there are transmission parts all over the driveway. I wasn't sure if just simply having a resistor means that you have a certain line pressure, or if the line pressure is a function of the resistance, or if the TCU or whatever thinks about the resistance (i.e. X resistance = Y line pressure)
Old 06-28-2002, 05:17 PM
museumquality
if you ask a dealer mech, they will just say leave as factory.
i stated this before in another thread. there are no guarrantees either way. we do know the stock option is a threat to our drive train. It is a fact that the clutches are controlled to deliver a soft transition between gears and the controller is the resistor.
this comes back to - try it - if it feels right go with it.
as far as tech data, i hve nothing formal to share, just a trans expert advise.
Old 06-28-2002, 05:27 PM
lee lee is offline
I haven't tried this on my newly rebuilt tranny, but on my old one I tried values from 8 to 16 ohms after the orignal failed (for the record, I tried, 8, 10, 12, 15, and 16).
Alldata says the factory spec is 9 to 15 (with I think the real value being about 10.5).
I couldn't tell any difference (between one resistor and another), but then there was no controlled testing involved, just me driving around town. Your mileage may vary.
Old 06-28-2002, 06:03 PM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
If you're certain that this is a path you want to go down try calling these guys and see if the Nissan part will apply to the 4EAT/
http://www.bulkparts.com/MM007.ASP?pageno=175
