Old 06-12-2002, 07:56 PM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
Part # for Tranny filters and which redline atf to get
Does anyone have the part numbers for the external atf filter and for the pan seal?. Also, is the internal one in a place that is accessable when the pan is dropped? If so the part # for that one would be great as well. Would I need anything else from Subie when changing my atf fluid and installing a cooler?
Finally, I see that there are 2 Redline atf's at summit racing which work for the Type II, any recommendations or ideas on the differences. One says racing other doesn't.
Thanks!!!
Old 06-13-2002, 12:23 PM
Ovidiu STAN Ovidiu STAN is offline
Try www.myoilshop.com
I am running RED LINE D4 ATF for a year now. It is still clean and the transmission is running smooth.
By the way : I have 2 oil coolers in series ( I bypassed the stock one) and my oil temperature is below 80degC all the time.
One of the coolers is in front (between radiator and condenser) and the second one is under the front, left (driver) fender.
I bought the tranny filter (from inside the tranny) from NAPA. It was around $15 and it came with the cover gasket.
Good luck
