Old 05-16-2008, 02:27 PM
Manarius's Avatar
Manarius Manarius is offline
Originally Posted by TomsSVX View Post
To be honest you *should* grease the plugs any time you take the coil off them...
Never have had to before. Also have never had to grease the coil boots either. Before this car, I had a 91 Legacy which had a central coil.
-Jason
-Obi Wan Kenobi
Old 05-16-2008, 02:35 PM
This is something I always did to my small-blocks when i would work them over... Better to be safe than dirty twice
Old 05-16-2008, 05:14 PM
Manarius's Avatar
The car drives as bad as if not worse than before. This is really getting on my nerves. I changed air filters also when I changed the plugs, I doubt that has anything to do with it, but it's a bit of information as well.
I made every coil look like this picture:
And every coil wire looks like this:
-Jason
-Obi Wan Kenobi
Old 05-16-2008, 06:09 PM
Wikedjuggalo's Avatar
Rebuilding
I see nothing wrong with them as mine looked the same :P are you sure you didn't damage the gap or the spark plug by tighting too tight?
Old 05-16-2008, 06:21 PM
Did you try to isolate it to one cylinder yet?
Old 05-16-2008, 07:22 PM
Manarius's Avatar
I haven't tried that yet. Matt suggested pulling the injector wires. A good idea?
-Jason
-Obi Wan Kenobi
Old 05-16-2008, 07:37 PM
Yeah
Are you taking it to Carlisle?
Old 05-16-2008, 08:01 PM
Manarius's Avatar
Yeah
Definitely. My cousin is graduating tomorrow, so I won't be able to be there until later Saturday evening. I also won't be able to come up until the afternoon on Sunday.
-Jason
-Obi Wan Kenobi
Old 05-19-2008, 04:04 PM
Manarius's Avatar
This case may be closed. Hocrest noted at the show on Saturday that a leaking exhaust may be causing the problems I have. So, I filled the exhaust crack today and immediately the ECU threw a code 22 for knock sensor. I picked up a sensor and pulled out the old one and it was all cracked up. That may be the answer to my problem after all.
Said knock sensor:
-Jason
-Obi Wan Kenobi
Old 05-20-2008, 03:37 PM
immortal_suby's Avatar
Thread Killah
I hope that is it, but when I changed my knock sensors a few years back as PM they both looked like that. Car was running fine.
Locker Link
2015 BRZ Limited 6MT
