Old 05-11-2008, 02:37 AM
Oh that's right, I had to pop the p brake on and off to get the driveline loose. It probably is brake drag.
Old 05-11-2008, 04:25 PM
This bolt is still stuck. Someone please break down the correct procedure for removing this thing before I start on the other side.
Old 05-11-2008, 04:36 PM
Re-tighten one of the inner bolts, that makes it easier to remove the outer bolt.
Old 05-11-2008, 04:43 PM
NEVERMIND HULK SMASH PUNY BOLT. Bolt out now.
Old 05-11-2008, 06:45 PM
Bell housing bolts.
Hardest thing, ever.
I don't see me getting this trans out in the next 5 hours.
Old 05-11-2008, 06:58 PM
ShiuludeSVX's Avatar
Put the bolts back in from underneath. If you ever have to do it again, it will be that much easier.
There is a "How to" document for this whole thing ya know.
The Worm
_______________
June '91 Claret LSL #1733, Enkei RS-5's x 16", Original Paint, accompanied by Beautifully speckeled Front Bumper, Sony Audio Components, Small Car Shift Kit, "How to" Hood Lifts {Perfect}, "15 Minute Suspension Mod"
Motorsport Floor Mats. Perma-Cool External T. Filter, New Front Axels {1/2008}. "Classic Radiators" unit "$36 coil alternative" and Tranny rebuild at 287k 8/2012
'05 Infinity G35 Coupe.
No Mods, 33K Miles
Old 05-11-2008, 07:22 PM
What.
Anyhoo, I'm following Tom's write up and am on step 9.
I'm on step 16.
How many bolts are there supposed to be? I only see 3.
I believe I have removed all the bolts as the motor has lurched forward a bit separating it from the trans.
Old 05-11-2008, 08:28 PM
kwren's Avatar
kwren kwren is offline
just 3.............
Old 05-12-2008, 12:09 AM
Trans has been out and dripping oil all over the floor for bout an hour now.
I think I dropped the plug in the oil when I was draining it way back.
Starting with the TCU Monday.
In the shower I noticed Ihav rug burn on my back from sliding around under the car so much even though I had a T, a sweater, and a tough work shirt on. Ouch.
Old 05-12-2008, 07:56 AM
Its called shirt burn... I have dealt with it many times before. Did you disconnect the torque converter from the engine??
Tomq
Old 05-12-2008, 10:55 AM
Wasn't that step six?
Or do you mean completely? It is still attached to the trans, I believe. I still have to get it out from under the car and towel off the mess it left but the trans is completely disconnected.
Old 05-12-2008, 10:58 AM
I haven't read that writeup in years, I have no idea what step is what
As long as the bolts are out it should disconnect easily... I have had a couple stubborn converts get sealed to the crank in the pilot bushing but its not very often.
Old 05-12-2008, 07:32 PM
Oh it came apart as soon as I loosened the top right bolt. Pulling it away was the hardest part.
Long bolts are looooooong.
