checked codes
so i checked for codes today
and i know that the long blink is 10 and the short is 1 my question is: i get one long blink and then one short one. then there is a pause. then i get 3 more long blinks and 7 short blinks does this mean that i have 2 codes, one as 11 and the other as 37? (11=crank angle sensor or circuit) (37=oxygen sensor, no. 2, left side)
Trevor Avondale, AZ 1992 LS-L Liquid Silver 126k "BXR6" Sold 3/23/13 1992 LS-L Claret 178k totaled 10/26/09 1987 BMW 325is 60% of the time it works, every time |
Yep, 11 & 37.
alright thanks
second question: in the how to document it says that after you've found the codes, you can clear them do i want to clear the codes after i fix the problems indicated by the codes i checked?
If you clear codes before you fix the problem, the codes will appear again. If you clear the codes after you fix the problem, they should not appear again (unless you haven't actually fixed the problem).
Thread Tools | |
Display Modes | |
