Old 04-30-2008, 11:00 AM
paulmeisterpk's Avatar
paulmeisterpk paulmeisterpk is offline
Sconnie
Send a message via MSN to paulmeisterpk
So, my gas cap is stuck on...
I stopped at a gas station two weeks ago on my way home from school to fill up. My tank was getting pretty close to empty too. I popped the fuel door, but I couldn't for the life of me get the cap off. It turns to the right and clicks as normal, but won't budge when I try to turn it to the left.
So I took my legacy to school and checked it last weekend after it sat for a week, and still couldn't get the bugger off.
Has anyone ever run into this before? and what should I try? I tried a big channel lock pliers to twist it off, but it didnt work.
Old 04-30-2008, 11:04 AM
I have never heard of that before. A member just lost his (I don't know how because they are secured to the car), but have never heard of one being stuck.
Old 04-30-2008, 11:11 AM
I have had people super glue things together on me, maybe you were a victim of this too.
blk 92' LSL w/ average mods
Old 04-30-2008, 11:15 AM
shotking's Avatar
shotking shotking is offline
Have you tryed a torch on it yet? J/K of course
Joshua
92 Ls-L pearlie 73,000 miles
Old 04-30-2008, 11:39 AM
bwb3's Avatar
bwb3 bwb3 is offline
Cruisin' in Gator Country
Actually it happened to me once at a gas station. After several minutes and rising panic a push down and turn broke it loose. Must not have put it on straight previously.
Gene
Gene and Ben
Old 04-30-2008, 11:56 AM
dcarrb dcarrb is offline
This is a long shot, but I believe a vacuum in a nearly empty tank can create enough suction to make the cap difficult to remove. If you're sure it's not cross-threaded, maybe you can remove the lines to the evaporative canister to let air into the fuel system, and see if that helps.
dcb
Old 04-30-2008, 12:20 PM
kwren's Avatar
kwren kwren is offline
not funny..
someone on this earth might take that as a serious.
Old 04-30-2008, 12:21 PM
kwren's Avatar
for that one
not
Old 04-30-2008, 12:22 PM
vacuum
^^^That's what I was thinking. It's hard to remember, but I think my cap got stuck ones. I just gave it a "Hulk turn puny cap" action and it came loose with a loud wooshing sound.
Old 04-30-2008, 12:45 PM
At least they would win a Darwin Award on their way out
Old 04-30-2008, 03:22 PM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
Not on any of my SVXen. Just a regular cap that you unscrew and place on top the spoiler while you fill up.
PaulMeister, the only way I can think of to remove a stuck cap is with excessive force. Something like a big stilson.
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
Old 04-30-2008, 03:43 PM
tiv0's Avatar
tiv0 tiv0 is offline
svxless
i dont know exactly of a way to do this, but if you could somehow heat up the plastic, it might expand a bit and then turn loose with some force
but ill leave the way in which you decide to do that to yourself...dont use fire...
btw, my gas cap is secured to my car; like every other svx ive ever seen
Trevor
Avondale, AZ
1992 LS-L Liquid Silver 126k "BXR6" Sold 3/23/13
1992 LS-L Claret 178k totaled 10/26/09
1987 BMW 325is
60% of the time it works, every time
Old 04-30-2008, 05:32 PM
Sconnie
I was thinking that it was vacuum too, but I figured that the pressure would bleed after sitting for a week. I may try popping my lines though.
Old 04-30-2008, 05:45 PM
ask the closest guy to open it for you
Old 04-30-2008, 06:00 PM
kwren's Avatar
If you go that rout....
Originally Posted by b3lha View Post
Not on any of my SVXen. Just a regular cap that you unscrew and place on top the spoiler while you fill up..
Maybe should get at least a couple
