Old 04-14-2008, 10:03 AM
sachmo12345 sachmo12345 is offline
Demons in my power locks.
Ok so since I have had my 92 the locks have acted really weird. The drivers side lock is not powered but the passenger side is. I havent really been able to find a solid chain of events that causes it to act up. I'll get in the drivers side (which I dont lock because the outside key hole is in really bad shape and feels like it may break if I'm not careful) and when I shut the door the passenger side door will lock and unlock or vice versa. Once the car is started I have no control of the passenger side lock, to unlock the door I have to turn off the car and press the key fob. Occasionally while driving around the passenger door will unlock or lock itself.
Does anyone have any idea what the hell is going on with my locks?
Old 04-14-2008, 10:46 AM
so you are saying the power lock on the driver's door does nothing??
Old 04-14-2008, 11:05 AM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
It sounds like you have a problem in the driver's side door lock actuator, or the wires that run from there to the control unit. If you are technically minded, I suggest removing the actuator and inspecting it carefully. Look for worn out or corroded tracks and water inside the casing.
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
Old 04-14-2008, 11:14 AM
My old 92 had door lock problems too. I ended up pulling the actuator to find it not connected to the lock arm. Since the driver's door lock actuator is also the "lock/unlock" switch it MUST be connected to the linkage in order work the lock system properly. B3lha is correct in suggesting to inspect the actuator as this is probably where your issue lies
Old 04-14-2008, 03:13 PM
pearlm30's Avatar
pearlm30 pearlm30 is offline
I remember someone else had a similar problem. Try disconnect the battery for 10 mins and reconnect.
94 Bordeaux Pearl SVX Lsi B&M cooler with Aux ATF filter. QC Kit Plus 06 Sti Gold Wheels. SOLD
92 Claret WRX 5 speed ECUTune 1AV1 Gold STI Wheels & more. SOLD
92 Teal SVX LSL lowered with Konig. SOLD
92 Black SVX LSL with B&M cooler & Aux filter. Small Car Shift Kit. Gone
94 Red SVX L FWDwith LSL Leather Interior. SOLD
92 Teal SVX LSL....with B&M cooler & Aux filter. Small Car Shift Kit. SOLD
95 Polo Green........With Trany Problem. GONE
Almost complete Rear Wheel Bearings Job with Pictures in my locker
My Locker http://www.subaru-svx.net/photos/user.php?pearlm30
Old 04-14-2008, 09:55 PM
That is correct. It can only be manually operated.
Old 04-15-2008, 08:15 AM
See post 4... I explained what happened when I experienced this a while back...
