Old 03-12-2008, 10:40 AM
JLHollowX13's Avatar
JLHollowX13 JLHollowX13 is offline
Send a message via AIM to JLHollowX13
anyone have these motor hoses??
im attaching pictures, they are the hoses directly in the center of the picture (you can clearly see the one on my intake, it has tape coming off of it haha) i was messing around one cold day and they snapped. anyone who has these and is willing to sell let me know, i hate rigging up my car like that. thanks!
Old 03-12-2008, 12:32 PM
wantafastsvx wantafastsvx is offline
hoses
just a friendly bit of advice. I would say you would be better off and getting some bulk hose of that size at an auto store and replacing it as any originals are more than likely brittle and gonna crack from the heat when moved. Might cost you 3-4 dollars. When i pulled the manifold everything under it got replaced which you can count on having to do as well cause all the other hoses will probably be just as dry and brittle. Just my .02
Old 03-12-2008, 01:38 PM
thanks, i didnt even think about doing that. that probably will be the best thing to do, especially since alot of my hoses ARE brittle. thanks again!
Old 03-12-2008, 01:50 PM
he's right... take the hose off, head to the parts store and buy a couple feet of every size you are going to need...
Old 03-12-2008, 04:23 PM
There are some hoses that are formed though, right? The big one that goes into the side of the throttle body, and a couple others. Can anyone list all of the pre-formed hoses so I have a shopping list?
Old 03-14-2008, 08:00 AM
hoses
I think you're talking about the hoses that go from the top of each valve cover to the bottom sides of the intake box correct? I bought some bulk hosing for those as well and never had any issues. However im sure someone will be able to post up the p#s for you. To be honest i have the ones i made laying on the table from the engine swap and they almost look like the formed ones now from the heat and everything. Just my .02 again though. Good luck. Be careful pulling that intake as there are many tiny little vaccum lines and sensors and stuff under there. So just take your time and make sure you see where everything goes. Oh yea also you might look into getting phenolic spacers if you are gonna pull the intake. And finally make sure you tighten the manifold back down to spec with the right bolts.
Old 03-14-2008, 10:57 AM
got 2 feet of hose yesterday, that was the perfect amount for me. got them in really easily and everything great now. now i need to find out if i can do that with the power steering pressure hose......
Old 03-14-2008, 11:19 AM
Originally Posted by JLHollowX13 View Post
... now i need to find out if i can do that with the power steering pressure hose......
For the high pressure power steering hose, you'll need to take it off and find a local shop that rebuilds high pressure hydraulic hoses. Or buy a new one from Subaru.
Old 03-14-2008, 02:05 PM
bwb3's Avatar
bwb3 bwb3 is offline
Cruisin' in Gator Country
Like Dave suggested, I had my high pressure power steering hose rebuilt locally for $30.00. Reused the fittings but new hose and crimps.
Gene
Gene and Ben
