Old 07-30-2007, 02:20 PM
Ironhydroxide's Avatar
Ironhydroxide Ironhydroxide is offline
SVXT6 Project
Unhappy NEED to Sell ALL Parts in 1 WEEK
Hey all, I am in need of selling all my SVX parts this week as i am going on a LDS mission.
here is a list of all the parts that i have pics of (this is most of the parts i have)
The pics will be labeled with the # of the item in the list so's you can decern them (Hint: if you press Ctrl and F microsoft explorer will open a search window. type the part you are looking for and press "find next" then you don't have to read 91 lines of parts )
1 Rear Bumper: Pearl, Some scratches
2 Formed Carpet: gray Some spots, might be washable??
3 Drivers Door Panel: No Switches Gray
4 Climate Control: With the Ecsaine color
5 Gauge Cluster: 105,000 not cracked
6 AC Evaporator: Housing is cracked
7 Blower Motor Housing: not cracked, no blower motor.
8 TCU Trany Control Unit
9 Rear View Mirror: Gray screw cover included, Not cracked
10 Small relay with mounting bracket: don’t know what it is or where it goes
11 Pass side Carpet covered Plastic: You know what I mean, under dash to cover wires
12 Pass side Door Sill: Small Crack, Barely Noticeable, Gray
13 AT Shifter stick assy: no handle, just assy with cable.
14 Trunk + fuel Door Pop: with cables
15 Fuse/Relay Box
16 Pair of Side Mirrors: Pearl Some slight scratching on paint, no cracks
17 Security Module: no fobs
18 Seat belt control unit
19 Door Lock Timer: don’t know what it does, but it is there
20 Stop LP CKR (that is what it says): don’t know what it is or does
21 Trunk Light: Not sure if it works (LAZY)
22 Another electronic doohickey (relay) with bracket: Same as 19 don’t know
23 power mirror switch: gray
24 Control Box for summat: don’t know
25 door lock actuator pair: both sides with 4 control rods??
26 lighted door handle pair: pearl, some slight scratches
27 trunk latch: not bolted to trunk lid
28 Cruise control Unit: with both relays on bottom
29 Crap Handle: bolts to a pillar on pass side
30 Trunk/Hood hinges: not sure which ones
31 pair of rear seat belt clips: short side with red button
32 broken front ash tray: ecsaine color, (should just throw it away)
33 park light and defroster switch
34 Shifter handle: no button for shifting, Has manual button
35 nother small relay
36 cener console: gray without rear ash tray
37 dash piece: smaller, closer to steering wheel
38 power antenna: haven’t tried it, but it looks good
39 Shift lock unit
40 electric units with bracket
41 ABS control unit: has 48 LHD 4WD AT sticker
42 rear wiper unit: with wiper arm
43 Shifter console?: cover that has P,R,N,D,3,2,1 on it
44 shoulder belt assy: mounts to center under console for auto shoulder belts
45 rear wiper fluid tank: with pump
46 Automatic Seat Belt Pair: both seem to work correct.
47 Front Window Track assy Pair: both units for the front windows
48 rear window track assy Pair: both units for the rear windows
49 Front Fender Pair: Right has small chiping on front section both have slight (hardly noticeable) dents
50 Trunk: black over pearl, has holes for usdm spoiler
51 pass seat: some pleather cracking
52 Spare tire: good tread
53 Right OEM Wheel: dented flat
54 Left OEM Wheel: Not dented (straight as I can see) slight tread left
55 Right OEM Wheel: straight (that I can see) mucho tread left Michelin potenza tire
56 Left OEM Wheel: straight (that I can see) mucho tread left Michelin Potenza tire
57 Dash: full width, has plugs for gauge cluster
58 Rocker panel cover Pair: both pearl Slight scratches
59 Rear seat: both pieces, no tears
60 trunk carpet: stained (possible cleanable) no tears
61 Pass door cover: has window switch
62 Rear quarter covers inside Pair: both with window switches
63 front mud guards / inner fenders Pair
64 Door trim pieces Pair: slight scratches pearl
65 Trunk panel
66 Wiper trim piece
67 Rear valance pieces Pair: where antenna goes through
68 wire guards: under carpet on both sides, White formed plastic
69 rear Apillar pieces Pair: both, no tears
70 front a pillar pieces Pair: Both, no tears
71 trunk panels Pair: in front of rear lights with acces cutouts
72 Trunk Spare Cover board: oil stained
73 OEM Muffler heat shield
74 Front Vent covers Pair: around wipers
75 Door hinges Pair
76 rear rocker panel trim pieces Pair: pearl some scratches
77 trunk lid trim piece: with access panel
78 access doors Pair: for side panels (tail light acess)
79 passenger visor: dirty Gray interior
80 Gray Trim pieces Pair: don’t know where they go
81 heater vent tubing
82 Plastic ring: looks like for the sterio, but I don’t know
83 plastic trim: gray
84 nother plastic trim: gray
85 Seat rail trim pieces: Black
86 Black plastic trim piece
87 Heater vent tube Y
88 OEM muffler: with OEM tips
89 Power steering pump: LS-L vehicle speed sensitive (I also have rack)
90 front bumper: pearl, paint chipping some places
91 Hood: pearl, 2 divots in center (not worth it IMHO)
The pictures of individual items are in my photobucket acct.
LINKY
Just give me a price you want to pay and what part you need. (i also have all the glass from the doors and the roll down glass from the rears)
if it dosent sell, i will be forced to trash all the parts, so PLEASE dont make Me Ruin all these good parts
Rusty
P.S.
I will ship parts if you pay ACTUAL shipping, (will email a pic of the recipt)
and it would be easier for me if someone could pick it all up at once (or it all shipped to one person)
PLEASE HELP ME
and pm asap
Old 07-30-2007, 03:35 PM
VICSVX's Avatar
VICSVX VICSVX is offline
Never Forget
Hey,
I need visors, center consol, the lower dash assembly under the steering wheel, and left tail light . My interior color is gray with clothe seats. How much (if you have any of the parts I need) are you asking?
I would aslo like to have the wing if you have it.
Could you provide a list of what all you have, I might be interested in more.....
Old 07-30-2007, 03:46 PM
SVXT6 Project
let me write up a list for all (will put it in origionall (SP?)) i have the center console, Drivers (i think Let me check) visor. i have the leather seats (LS-L model) so i don't know if the other parts will be the same.
Let me know if you want what i got.
SVXT6 (Pearly) just got running 201,000 (body) 105,000 (engine)
Honda FT500 Ascot [Red]
Old 07-30-2007, 04:26 PM
VICSVX's Avatar
Never Forget
Dang, I have 94 L...the center consol should work though right?
But yeah, that'll be great if you make a list of parts you have
Old 07-30-2007, 04:58 PM
SVXT6 Project
well the center console should be the same specs as far as mounting goes, but the one i have is wraped in leather so in worst case, you will have an uber nice console in a not so nice interior car.
Old 07-30-2007, 06:27 PM
Sov13t's Avatar
Sov13t Sov13t is offline
Interested... looking forward to seeing the pics.
Thanks,
-Sov
Subaru SVX 94' Laguna Blue - 8.5 C/R Built Motor, 6spd
Old 07-30-2007, 06:52 PM
SVXT6 Project
still uploading pics, i have a TON
Old 07-30-2007, 07:15 PM
gsodonis's Avatar
gsodonis gsodonis is offline
Maf?
Dibs on the MAF if you have it available.
Old 07-30-2007, 08:39 PM
SVXT6 Project
bump for the pics
in the link there are 258 different pictures/angles of the above stated parts. the name of the picture coincides with the number of the part in the list of the first post
thanks
Click the underlined LINKY in the first post under the list
PS no MAF Sorry
Old 07-31-2007, 12:04 AM
davew833 davew833 is offline
Congrats on your mission call. My father served a mission to Germany, but that was many years ago.
PS: You don't have a good windshield, do you?
davew833@yahoo.com
Former 6-time SVX owner
Old 07-31-2007, 10:39 AM
SVX PlayBoy SVX PlayBoy is offline
Send a message via AIM to SVX PlayBoy
dibs
needing the right OEM rim, number 55 on your list. PM Sent
Old 07-31-2007, 10:42 AM
SVXT6 Project
no windshield, or sunroof for that matter.
the po pulled the windshield, trany, sunroof, all exterior lights, drivers seat, rear diff, and drivers window switches.
ALL FOR JUST A DEAD TRANNY!
but at least i got an engine out of the deal.
Old 08-15-2007, 06:06 PM
97 SVX 97 SVX is offline
Send a message via ICQ to 97 SVX Send a message via MSN to 97 SVX Send a message via Yahoo to 97 SVX
trunk release
Happen to have the trunk release (plastic) assembly (next to drivers seat)\Ian
