Old 04-16-2007, 06:00 PM
SVXgarcia SVXgarcia is offline
Send a message via AIM to SVXgarcia
Bleeding Brakes
What's the proper procedure for bleeding the SVX brakes?
Old 04-16-2007, 06:43 PM
JaySVX's Avatar
JaySVX JaySVX is offline
Believe it's driver front, pass rear, driver rear, pass front.
*No SVX at the moment...*
1987 Winnebago Elandan 35'
2001 Yamaha Roadstar 1600
Old 04-16-2007, 09:11 PM
Thanks I will try that. I've never done this before.
Old 04-17-2007, 04:21 AM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Buy yourself one of these.
Old 04-17-2007, 06:26 AM
JaySVX's Avatar
If you don't disconnect the brake lines you shouldn't have to bleed them though. I just had my brakes all apart, no bleeding necessary, and i replaced my pads and rotors. Just use a c-clamp to recess the pistons back into the calipar if your changing the pads. Much easier and cleaner job that way.
Old 04-17-2007, 09:30 AM
richardstanley's Avatar
richardstanley richardstanley is offline
Lover of Alcyones
True you dont HAVE to bleed, but your supposed to each time you change the pads
Current:
95 svx Ls-L (Black)
91 5sp awd xt6 (red)
Had:
91 xt auto awd(lt blue)
85 xt 4wd turbo 5sp(blue/white)
86 xt 2wd turbo 5sp(black)
85 xt 4wd turbo 5sp(silver/white)
89 xt AWD 5sp (white)
85 xt 4wd turbo 5 sp sold to Zukiru (silver)
86 xt turbo 2wd 5sp (silver/black)
Old 04-17-2007, 10:50 AM
Yes, it is a good idea because the fluid tends to draw moisture. I do partial changes by sucking the tank dry and adding new every other oil change. It seems to keep it fresh and clean.
