Fuel gauge finally died
Well after only 267,000 miles my fuel gauge has found a resting spot below E. Has anyone replaced their fuel pump and gauge sending unit? How much trouble is it? Should I just continue using my trip odometer to determine when to fuel up!!
'92 LSL TEAL 277,000 miles Trans (on # 3) Engine (on # 2) "NEW" VISORS '03 Forester XS 214,000 miles '05 Outback 3.0R |
Fuel pump shouldn't have anything to do with it, but that's the easiest to replace. I would guess it's either the sending unit or the guage itself. The guage you can replace, i would get a donor instrument cluster from a wrecked car, personally, as OEM would be a nightmare. Also you could get an aftermarket fuel guage and mount it somewhere. The sending unit i'm not sure where it is, but you can check it with a multi-meter to see if it's good or not, via some wires in the dash or under it.
*No SVX at the moment...* 1987 Winnebago Elandan 35' 2001 Yamaha Roadstar 1600 2004 Ford Excursion Eddie Bauer, 6.0litre Power Stroke Diesel - Daily Driver. Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways, scotch in one hand, body thoroughly used up, totally worn out and screaming HOOOOYA !!!!! |
I would say it's the sending unit contacts being corroded. That's the way it usually is on the Legacys. The replacement of the sending unit requires that one remove the fuel pump from the car. Unfortunately, they usually just corrode up again.
-Jason (8/23/07-Present) 1995 Subaru SVX LSi (197k) Polo Green (#1102) 03/95 Mods: DDM Tuning 4500k 35w Low Beam HID, 100w H3 Bulbs, Extra Ground Cables, 15 minute $12.96 mod, svxfiles designed transmission mount (), sporting a "new" tail light bar, silver BBS rims, custom power steering cooler (one that doesn't dump ATF constantly), new negative lead cable, no more third or fourth gear (1977-Present) 1977 Chevrolet Corvette (81k) Silver (12/01/2011-Present) 2005 Subaru Outback 2.5i Limited 5MT (97k) I have a bad feeling about this. -Obi Wan Kenobi |
I've replaced the fuel pump and sending units together-- it's not tremendously hard. It helps if you have the replacement beforehand to see how it fits together since the whole assembly has to fit down into the tank through a 4" hole under the back seat. It's kind of like building a ship in a bottle. The good news is that the pieces clip together on a hanger inside the tank, and that it's all done from inside the car-- no need to drop the tank or get under the car.
Wow! It only made it to 267,000 miles...you should really complain to Subaru. Those bastards!
I agree with Jason.....I had a legacy also and the sending unit does corrode, my gauge would act funny every now and then.... Also check your battery terminals and clean off any buildup with a wire brush.
J shows the location of the sensor
- John ASE certified Master Tech W/ X1 Twin City Fleet repair, St. Paul, MN need work done? Have tools will travel
Does the gauge work sporadically? Then the contacts are going bad.
Or is it just constantly below "E"? Then I would guess the gauge itself or a broken wire along the way.
Thanks for the input folks. I guess I'll check the wiring first then if all else fails I'll try to replace the pump and sending unit. At least I won't have to drop the tank. I did the same job on an '88 bronco. That was a bear.
