Old 01-07-2007, 09:07 PM
Boosted's Avatar
Boosted Boosted is offline
Mystery Rattle
So I've got this rattle that's making me nuts. I first noticed it in a parking lot, a violent rattle right before an upshift or downshift. Then the other day I parked on an incline like this / with the nose up, and I could hear it at idle. So I get home and play with it a bit, and notice that it begins to rattle (though not as loudly) at about 2000rpms when I rev it in park.
My first suspision was that is was all those heatshields at the "Y" in the exhaust, but I removed them, and it still rattles. It really sounds like some sort of heatshield or dustshield rattle to me. But my dad suggested that it could be a loose torque converter. Any other suggestions or experience?
'92 SVX LS-L - 4.44 Tranny
'67 VW Fastback - Undergoing restoration/ej257 conversion.
Old 01-08-2007, 01:53 AM
19svx94 19svx94 is offline
Send a message via AIM to 19svx94
if it is based only on rpm's then i would say its your resintor gone south, i had the same problem and when i eliminated the resinator while doing a 3in catback to a magnaflow getting prepared for a turbo the sound went away "i already had the magnaflow in, and got the catback for free so i just did it"
Old 01-08-2007, 09:35 AM
wannarace928's Avatar
wannarace928 wannarace928 is offline
Send a message via AIM to wannarace928 Send a message via Yahoo to wannarace928
Classic SVX
The resonator on mine is bad causing it to rattle. I also thought it was a heat shield because one is loose but we removed it and a shop confirmed its the resonator. Most times it only rattles when driving forward around the 1500-2000rpm range. Kinda annoying.
Old 01-08-2007, 09:46 AM
msvx95's Avatar
msvx95 msvx95 is offline
It's just a phase
Can you get someone to give it gas while your under looking for the rattle?
Keep it in P or N though and obviously on jacks w/emergency brake on
1995 Subaru Svx L / AWD
Old 05-30-2007, 04:28 PM
Was the rattle ever found? It could also be the large heatshield between the exhaust and the driveshaft.
