Old 12-24-2006, 11:26 PM
Originally Posted by HighwayUFO
The slip does occur at 3,000 RPM in every gear. Third gear is probably the best gear I have at the moment because I can get it up to 4,000 RPM before the gear slips out, but I have to wait until I get past 3,000 RPM before I can roll on the throttle more liberally.
Yesterday was the first time a I had a problem climbing a hill. It feels like the applied torque is causing the slip and the torque of the car is very responsive up until 3,000 RPM.
Hope that helps.
You say that slip occurs in every gear and at 3,000 RPM. You are asking a lot for a diagnosis from those who have not even been in contact with the car. I would be checking the line pressure as a first off in the diagnostic chain. A test plug is provided for this purpose. That said, there are several possible causes.
Why has not the "shop" run a proper series of tests? Is this beyond them? If so go somewhere where someone knows what they are about. Don't accept a simple, you need a complete transmission rebuild, unless they can tell you exactly why and what is wrong.
