Would these rims fit an svx
16x8 5x114.3 +33mm offset
Brian |
I ran a 8.5" with 35 offset, so I'd say yes.
did they rub at all, even with the steering wheel pinned to one side or the other?
Brian |
They look sweet.
I think 40 offset is recommended, but people have used other sizes with no problems. Joe
He's asking $500 with no tires.. too much?
Brian |
BBS crosswires are standard on the SVX in Japan '95-'97, but not this style.
One useful piece of advice I will give you Brian. Check with the guy what weight these rims are, preferably without tyres. The standard SVX rims we have are actually of a very high quality. They are lighter and stronger than the vast majority of aftermarket rims. If these BBS rims are heavier, they will change the unsprung weight for the worse, and you will notice a difference [degradation] in handling and braking. Joe
Compliments of the season Joe, Trevor.
Well my stock wheels have paint chipping off them everywhere.
Brian |
Edit P.S. I think you will find that the wheels you have illustrated have a big disadvantage, in that a normal socket may not fit fully down the recessed wheel nut hole. My son has a set with this problem.
Trevor, New Zealand. As a child, on cold mornings I gladly stood in cowpats to warm my bare feet, but I detest bull$hit! Last edited by Trevor; 12-17-2006 at 09:39 PM. |
Does anyone know about how you would "refinish" the original rims? It seems to me it would just be a paint material??? mine look horrible. The center caps are white.The rims just look aged. I never would get any other rims. I've never seen any that made an SVX look better.
In a word: TRANSWHEEL. I cannnot speak more highly of them.
Check my post #6 here http://www.subaru-svx.net/forum/show...602#post442602 More photos in my locker: http://www.subaru-svx.net/photos/user.php?svxcess|37574 .
If you apply some elbow grease and use some wet emery paper, you can do the wheels yourself with a couple of spray cans. You do not have do the insides, simply clean this area up a bit. P.S. If you stick to silver paint, you will find that this is user friendly and does not show up slight errors. Go to it. and have a happy Christmas.
Trevor, New Zealand. As a child, on cold mornings I gladly stood in cowpats to warm my bare feet, but I detest bull$hit! Last edited by Trevor; 12-17-2006 at 11:36 PM. |
I have to disagree about other rims not looking better on the SVX I have a set of 17s on my 92 and it made the car look 100x better. I have a picture of it on my myspace
http://profile.myspace.com/index.cfm...endid=31633014 I paid around 350 for the set new. I got them from a rim wholesaler. Everyone said the rims made the car look much newer. The stock rims are just plain ugly, but easy to clean. now if you want your rims to look like new again put your car on blocks and take your rims to a tire shop and have them remove your tires then drop them off at any powder coaters shop. it should run you about 45-55 a rim. they will strip your rims pain and powder coat them...this will last forever and never fade. it is tons more durable. My stock rims look like new from when I had this done.
1992 SVX black/redish 62k awd, rims, brakes..and a few add ons for extra HPs |
