Old 11-10-2006, 12:33 PM
anthonybuchanan anthonybuchanan is offline
18" wheels recommendations?
Any recommendations on 18" wheels and tires.
Will they cause to much wear from the extra work the struts have to do ?
What is the widest 18" tire used by anyone here ?
Old 11-10-2006, 01:03 PM
The 05 STi rims are becoming more popular. You would probably want to limit to 18x8 with sufficient offset.
Old 11-10-2006, 01:41 PM
Is the ride a lot more bumpy ?
Old 11-10-2006, 02:12 PM
I would assume so. I still have stock rims but I would think that since there's less sidewall to flex there's less bump absorption.
Old 11-10-2006, 05:03 PM
Sr240sx's Avatar
Sr240sx Sr240sx is offline
The car has an excellent ride regardless. You may notice it to be a little less forgiving over large single bumps, but you won't notice any "jarring" of the ride, because that's all strut/spring.
My '95 SR20DET powered 240sx track car.
http://www.cardomain.com/ride/2161953
Old 11-10-2006, 05:13 PM
AFBeefcake's Avatar
Subaru Swapper
I run 18X7 on my car and the ride is stiffer. I can tell when I switch from the stock winter rims to my summer 18's. by going to 18" your going from side walls that 2.21 inches to a side wall that is only 1.77 inches. Its going to be stiffer.
2005 Legacy GT
My WRX's Cardomain Page
Old 11-12-2006, 05:55 PM
solarsvx solarsvx is offline
Send a message via AIM to solarsvx
18" axis decades with rear maxis lip, 18+8 with 40mm offset works and looks good
2008 evo x with sss package
430 hp 380 torque stock turbo with basic bolt ons
12.56 @ 109 fully weighted 3,500 lbs
Old 11-13-2006, 08:37 PM
SubaRyu's Avatar
SubaRyu SubaRyu is offline
Domo Arigato
I just installed 18' on mine last month. I don't notice the ride quality getting worse so much. Probably the new quiet tires are helping.. I let many people ride with me, but nobody noticed anything....so far.
-Ryu
Links:
2004 Honda S2000 (2008~)
1992 Subaru SVX LSL Liquid Silver (2007~2008)
1996 SVX LSi Bordeaux Pearl (2006~)
2002 Lexus IS300 Sportcross (2005~)
1992 Subaru SVX LSL Pearl White (2001~2005)
1994 Mercury Sable GS (1999~2001)
1/43 Scale SVX Models
[SIGPIC][/SIGPIC]
Old 11-14-2006, 08:51 AM
Subaryu, what manufacuter/size wheels and tires did you get ??
I'm always on the lookout for a quiet tire.
Old 11-14-2006, 08:20 PM
SubaRyu's Avatar
Domo Arigato
Mine is Nissan Murano stock 18" rim.
I forgot how much, but it has some off-set. 225/40/18 tires will fit good. It's Fusion tires.
-Ryu
Links:
[SIGPIC][/SIGPIC]
Old 11-14-2006, 08:31 PM
RX8 wheels are a nice choice. I'm going for some 18'' Kazeras fitted for the RX8.
Old 11-14-2006, 11:48 PM
Speedklix's Avatar
Locker Link Solution
I still love that look too. Thought about doing it more than once.
-Mike
[SIGPIC][/SIGPIC]
Catch you next at: ? Auto-X ?
Old 11-15-2006, 05:00 PM
SomethingElse's Avatar
word words wording
Ive got the chrome ones 30+ mm offset. The rear rubs over bumps and stuff but the car has 170k miles so its time for springs
Eric
Old 11-15-2006, 07:39 PM
SubaRyu's Avatar
Domo Arigato
I was seriously thinking about that RX8 rims as well. But I found good deal on Murano rims first, so I took that.
-Ryu
Links:
[SIGPIC][/SIGPIC]
Old 11-15-2006, 07:50 PM
SubaRyu's Avatar
Domo Arigato
Nice chrome rims and black SVX!
It has 30mm? Yeah when I picked up my car the right rear tire was rubbing. Only right side. Hmm that's strange. So I checked it and found the innner fender was popping out and rubbing the tire. So I just pushed it back, and problem solved!
Murano rims was good deal. I guess people sell stock rims pretty cheap since they don't use them after they get new rims.
Still thinking about what to do with center cap saying "Nissan" though!
Here is the link to photos!
Still
-Ryu
Links:
[SIGPIC][/SIGPIC]
