Old 10-03-2006, 07:11 PM
shotgunslade's Avatar
Calipers Wanted
Does anyone have a set of used calipers, even non-functional that I can borrow for a few months. Ordered a set of new front and rear cadmium plated calipers from brakewarehouse.com. Don't think I will be installing them for a couple of months, but want to get the core charge back sooner. So, will borrow your spare set of calipers, even if non-functioning and in a couple of months when I install the new ones, will send you a set of fully functional, but ugly calipers.
Obviously, will pay all shipping charges. You guys know I've been around the net for a couple of years and, at least so far, have been reasonably trustworthy. Thanks
Old 10-03-2006, 09:55 PM
Budfreak's Avatar
Budfreak Budfreak is offline
Banned
PM sent.
