Old 07-24-2006, 12:29 PM
WGJ WGJ is offline
Wtb: Rad Fan
Fixed my old one and now it's died.
WGJ
Old 07-24-2006, 01:24 PM
mikecg's Avatar
mikecg mikecg is offline
Which side? I think I have a good driverside.
Old 07-24-2006, 04:02 PM
I actually have 2 identical fans on mine. I blame the previous owner(s).
Old 07-24-2006, 11:43 PM
SSSVX's Avatar
SSSVX SSSVX is offline
One teal and One yellow
But have they given you any problems?
PS: Why are they different? Most of the times they run together...
-SSSVX
92 LS-L TEAL since Aug '01
92 LS-L YELLOW since Mar '05
Old 07-25-2006, 10:02 AM
I believe one has 5 blades while the other has 6. I've never replaced mine but the holes for the bolts keep needing larger washers to hold them in place.
Old 07-25-2006, 12:03 PM
My one upper tab was almost gone so I took it off, and with the fan laying front down on a workbench, I made a mold with some aluminum foil and poured JB Weld to replace the tab. After leaving it set, I trimmed some of the excess and drilled a hole in the proper place and it's been holding nicely since. If you want you can hit it with rattlecan flat black and it won't even look out of place.
Old 07-25-2006, 01:56 PM
Mr. Pockets's Avatar
Moderator
I have two identical fans on mine. I took the wrong one out of my mom's parts car. It works fine, but doesn't mount as easily. I haven't had a problem, but some day I'll swap it for the right one.
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 07-26-2006, 06:23 PM
SSSVX's Avatar
Is that more blades is Always better? Say, if one of the fans stopped working and I upgrade to a better and more powerful fan...would that cause any problem?
*better not happen*
-SSSVX
Old 07-26-2006, 11:45 PM
WGJ WGJ is offline
Thanks Alot I Wuz Gonna Ask You That Question...
[QUOTE=SSSVX]Is that more blades is Always better? Say, if one of the fans stopped working and I upgrade to a better and more powerful fan...would that cause any problem?
WGJ
Old 07-27-2006, 10:32 AM
I would say the more blades of the same size the better but I'm sure there's an optimal amount for airflow vs noise.
