Old 06-28-2006, 04:36 PM
Motorsport-SVX's Avatar
Motorsport-SVX Motorsport-SVX is offline
check out www.planetsvx.com
Shifter adjustment
I did a trans swap auto to auto just the norm
and after it was done sometimes when you put the car
what says Park on the dash and on the console shifter part
it wont start.
Something with the nuetral safety switch not in adjustment
I didnt see any adjustment under the car, has anyone run into
this before ?
My mom will forever live in me and
never be forgotten, one day Ill see her again
CLICK the LINK below to Visit the SVX Store:
http://www.planetsvx.com
http://www.motorsportwarehouse.com/svx/sig2.jpg
Cars in the garage:
92 Toyota Soarer Single Turbo JDM RHD
70 Boss 302 Mustang 39k original miles
97 SVX Lsi
92 Liquid Silver Murano-ized (1st of its kind)
71 Cougar Xr7 Conv 351c 4v 4spd
69 SS Camaro 350
71 Nissan RHD Fairlady Z
70 Stang Fastback
70 Amc AMX 390
71 240z
89 Conquest TSi w/ 5.0 v8 swap
84 Mustang GT Turbo conv
"good, if it bleeds, we can kill it ....."
Old 06-28-2006, 06:44 PM
immortal_suby's Avatar
Thread Killah
I had Ron Mummert do that to my car when I put in the new tranny. He told me it was the ripemoff industries starter immobilizer system.
You should be able to adjust the linkage to get it right.
Locker Link
2015 BRZ Limited 6MT
Old 06-28-2006, 07:13 PM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
Generally... Japanese cars have a neutral start (inhibitor switch, to them) mounted with two bolts to the transmission, behind where the shifter cable/arm attach to the transmission. Place the tranny in neutral. It's easier to remove the arm (use channelocks if nescessary to hold the arm) and remove the nut, then the shift arm. Look at the switch, there should be a small notch in the plastic portion of the switch that will align with a slot in the portion that keys to the shifter shaft. Loosen the two attaching bolts and rotate the switch until the notch/slots align, then retighten the two screws. Reattach the arm and cable and you should be good to go.
Then again, the SVX might be totally different and none of this will apply.
Old 06-28-2006, 09:58 PM
LOL thanks Beav. (and everyone) sounds like you have done this
once or twice before
Ill give that a shot tomorrow and see how it goes.
Cars in the garage:
97 SVX Lsi
69 SS Camaro 350
70 Stang Fastback
70 Amc AMX 390
71 240z
Old 06-29-2006, 06:14 PM
Nemesis Destiny's Avatar
Nemesis Destiny Nemesis Destiny is offline
6MT STi-ified, now with R180!
Send a message via ICQ to Nemesis Destiny Send a message via MSN to Nemesis Destiny
Happened to me last week with a 91 Legacy Turbo we have sitting on the lot. I couldn't figure out why it wouldn't start; I just thought the battery was toast. It was toast, but the shifter was also not registering being in park properly, as I eventually figured out that the car would start in Neutral. I vigorously moved the shifter back and forth a few times, and that seemed to clear up the problem.
1992 LS-L Touring, Liquid Silver w/ Black, 110k mi. "Alice." Rebuilt title. Mods: WRX 6-CD changer, 17x8" Motegi LC-12 (16.5lbs), PWR rad, Perrin LCP, JDM v.8 6MT + R180, Koni + Ground Control (325f/280r), Earthworm Bushings. Awaiting resto.
1994 LSI The legendary "Shotgun Slade" 110k mi and still going strong!
2005 Outback XT Limited 5MT, Obsidian Black Pearl, 211k km, daily driver.
1999 Mazda MX5 base 5MT, Twilight Blue Metallic, 152k km. "Twilight Sparkle" Summer daily driver!
2007 Honda CR-V, some awful shade of light green *yawn*
1992 LS-L Touring, Ebony Mica, 176k kms. Parts car. SCRAPPED.
1992 LS-L, Dark Teal, 367k km. "Wintergreen" the winter beater.*SCRAPPED due to rust*
