Guess who can't have nice things?
I've had my SVX out for less than a week, and I've managed to rub the right side of the car ever so slightly against the garage door frame. On the right rear wheel arch I have a very thin rubbed white line.
Anybody have any suggestions for getting it off? I once used lacquer thinner to remove squirrel-applied paint from my Justy, but this paint was applied to my car much differently. Instead of being gently deposited on the surface while wet, it was dry paint that was rubbed on. I've seen mineral spirits and polishing compounds suggested. I could try the lacquer thinner I have.
I also would like to know how to get very thin paint scrapes off my bumpers. (:
Red on the front from a push-cart corral that was encased in ice, and white on the rear, not sure what it's from or how it got there.
After borrowing my sister's Baja, I used a fingernail to scrape a white stripe that was left on the passenger door. I then did a quick coat of Meguires NXT (?) and it looked great.
If you can't scrape it off with a fingernail... a paint thinner type solvent should work. These aren't exactly great for your clear coat, but if cleaned of well afterwards, it shouldn't cause trouble. I have succesfully used gasoline for this type of situation before.
-Aaron SVX: '92 Dark Teal 101k '97 Legacy GT Wagon: dead '99 Civic Si: daily driver... stolen and stripped with all my tools! '92 Yamaha FZR 600: garage 2011 Jetta: Daily disappointment |
Possibly some super fine sand paper and wet sand it? Just sand enough to get the scrape out and then hit the spot with a good coat of polish.
1992 SVX LS-L: Now TomStock Stage 3... 6MT, R180 Rear, Tomstock Short Shifter and hard rubber mount, Group N Motor and Tranny Mount, Stage 2V6 Chip, Z32 MAF, Stage 3 CAI, Stebro, Intake Cams, 17" STi BBS Powder Coated Black, Bridgestone Potenza RE070, and Koni inserts w/Mychailo's Springs! Sand Diego SCCA Solo 2 #308 RIP 84 VW Scirocco 02 WRX 88 XT6(regret the day I left her behind) socaleuro.com They like the flat 6... Check My New Homepage.. |
I have also seen people use corn starch and water for very small blemishes. Make a paste, and use a buffer, and a very light hand.....
I'm not a REDNECK! I am an Appalachian-AMERICAN!! "Can't go to work today. The 'voices' said to "Stay home and clean the guns". Most famous Red-Neck last words... " Hey Everybody, Watch This!!) http://s306.photobucket.com/albums/nn272/subi-crosser/ Jerry Last edited by subi-crosser; 06-27-2006 at 11:48 PM. |
Mr.Pocket,
The answer for your question in this thread is You. Because you've been driving a small car long enough so you're not used to your bigger SVX, perhaps. Could you show us some pictures of your scratches? But I don't know how similar your conditions to my friend's, my friend scratched her new Suzuki with the garage door as well, it was great that she could use some top-quality scratches remover to take care of it.
-SSSVX 92 LS-L TEAL since Aug '01 92 LS-L YELLOW since Mar '05 |
We need to see a pic to be able to guide you ...
try some 3M Imperial Hand Glaze on it - also an awesome paint polish before you wax it.
i've removed various scratches, oxidation, adhesive from removed dealer badging, and other crap with it.
Alan 1987 928 S4 (Black) SOLD! 1997 SVX LSi (Ebony) SOLD! 2005 Legacy GT (Silver) [Cobb Stg 2+] SOLD! 1987 928 S4 (Black) SOLD! 2005 Forester XT Premium (Crystal Gray Metallic) SOLD! 2008 Lancer Evolution X MR (Apex Silver) [Cobb Stg 1+] 2015 Outlander Sport 2.4GT AWD (Mercury Gray) 2013 G37xS (Obsidian Black) |
I've had luck with a paper towel sprayed with WD-40.
'92 LSL TEAL 277,000 miles Trans (on # 3) Engine (on # 2) "NEW" VISORS '03 Forester XS 214,000 miles '05 Outback 3.0R |
I use Clay Magic claybar (Meguiar's also sells a claybar which is very good). Available at any Autozone.
http://www.claymagic.net/ClayMagic-Products.htm You basically spray a soapy 'lube' over the area you wish to clean, shape the clay to fit over your fingers and rub the area with light to medium pressure. Oxidation, paint overspray, oil, tar, grease, insect guts and bird poop comes right off. I've used it on my brand new WRX as I noticed some weird black lines that marked the edges of the white plastic wrap that was placed over my car during shipping. The lines came right off and the clear coat on my car wasn't harmed in any way!
Try Meguiar's Scratch X Fine Scratch & Swirl Remover. It comes in a black plastic tube and is "clear coat safe." It is specifically formulated to remove light scratches & swirls, oxidation & blemishes and "bonded contaminants" on your paint. Your rubbed-on paint should come off with this product. I trust Meguiar's products. My suggestion would be to try the least "invasive" type products first before going to harsh solvents or sandpaper. If WD-40 and a paper towel will do the job, then no need to risk your paint for anything else.
Preston |
Thanks, Preston. I have been very happy with Meguiar's products so far - I'll give that one a try. If it doesn't work, maybe I'll try some of the more severe.
Toothpaste?
