Old 12-02-2005, 02:17 PM
PhillsSvx
What can i do to keep the doors from freezing shut?
ok im tired of this my door seals frees every year and today i went to open it and tore half the rubber around the door off what can i do to keep this from happening?
thanks
Phill
Old 12-02-2005, 02:56 PM
Wax the door jam where the gasket hits the body. Use rubber treatment (armor all, etc.) stuff on the gaskets.
Old 12-02-2005, 03:14 PM
SVX_MY_BABY's Avatar
I keep the door waxed and use a light silicone on the seal. I apply it to a rag and wipe it on. (Sorry I don't like Arm or all).
Old 12-02-2005, 03:16 PM
n00b on demand's Avatar
Silicone spray on the inside of the door.
Old 12-02-2005, 03:29 PM
On the rubber gasket of the car body. Hadn't thought about the door gasket.
Old 12-02-2005, 03:51 PM
PhillsSvx
Ok thanks you guys im going to go to walmart now and get some because we are goingto get 4 inches tonight thanks again
Phill
Old 12-02-2005, 07:20 PM
makalii's Avatar
makalii makalii is offline
Move to Hawaii!
Gary
'92 "Beaujolais, nee Claret" LS-L ; ~180K; Build date 5/91, #1047
Old 12-02-2005, 07:28 PM
SVX-FF's Avatar
SVX-FF SVX-FF is offline
Live it, Love it, Breathe it
Silicone spray works great. I did all the door and trunk seals. We get some cold cold nights and I have not had any problems.
Remember the trunk too. That is if you use it.
Steve
03 Ford Expedition(hers)
Are you in?
My Old Locker
A 4.11 Founding Father
Reading IX
[SIGPIC][/SIGPIC]
Ya I was there
Old 12-02-2005, 10:01 PM
intelisevil's Avatar
<<<Alcyone
Phill
Only four inches? Here's my weather report - I live at 1400', in the North area . . .
a winter storm warning remains in effect until 10 am pst
saturday.
snow showers will continue into saturday. snow accumulations up to
around 12 inches are expected in the foothills through saturday.
the snow level in the north will be lowering to between 500 and
1000 feet tonight and early saturday...with a snow level near
1500 feet in the south. snow levels will rise back to between
1000 and 1500 feet in the north and 2000 feet in the south later
saturday. the snow showers are expected to decrease later
saturday.
Saturday morning, I'm going to drive my wife to work:
saturday.
snow will continue at times into saturday. the snow will be heavy
at times. an additional 2 to 3 feet of new snow is likely this
afternoon through saturday...with storm totals up to 4 feet.
storm totals of 18 inches to 3 feet are likely near the passes.
the snow will decrease later saturday.
This ought to be a good test of the SVX, the Hakkapeliitta's and my nerves.
I'm gonna make snow angels with my SVX!!!
Dan
Pentiums - Melt in your PC, not in your hand!
Project - '92 Claret - Purchased May '06, 99,XXX Miles. Includes two bad engines and one bad tranny, cracked windshield, otherwise mostly complete.
His - '92 Ebony Pearl - Purchased Dec '05, 134,687 Miles. Parked, TC Seal(?) is leaking.Daily driver - 140,500 and climbing.
Hers - '92 Teal - Purchased Aug '05, 129,050 Miles. Daily driver - 160,000 and climbing.
PWR Radiator!
Problems:
Antenna doesn't work - Bought a 'new' one - Too cold to install . . . OK, it's warmer but I have other projects too!
Ticking from front of engine, passenger side - Stuck lifter?
Old 12-03-2005, 02:06 PM
PhillsSvx
Ok well i took all of your advice and used wax and what not on my doors. This morning when i got up it was 28 degrees out and 3 inches of snow usually i would half to pry on the doow well it opened right up. but the rubber that tore off yesterday will cost 75$ bucks to Replace if any of u have the pice i need that goes from the drivers side mirror over the window let me know .
Thanks to all of you for the tips
Phill
Old 10-14-2006, 09:23 PM
DWAYN DWAYN is offline
door freezing
I tried vasoline last year. the door still froze and it was messy.
so i leave the rear seat down for those days when the door won't open and come in through the trunk which doesn't freeze.
one could also add a remote start and let the car warm up until the door opened.
i am wondering if wind deflectors would work.
where would you get wind deflectors anyway.
DWAYN
Old 10-14-2006, 10:05 PM
kuroneko_sama's Avatar
kuroneko_sama kuroneko_sama is offline
aka sir_romeo
Send a message via MSN to kuroneko_sama Send a message via Yahoo to kuroneko_sama
last year i simply used the spray i had leftover from my audi convertible.... basically its designed to de-ice the back plastic windows of a convertible so you dont use a scraper and shatter the plastic.
most stores sell it, its jsut a window de icer designed for convertibles
i also found that pouring hot water along the seam ofthe door doe a good melt job, jsut time it to open before ice forms
(its gotten as cold as 30 below here in the early am.... ive seen antifreeze freeze...how ironic)
this year ill let my autostarter do much of the work
I Leave late and STILL manage to arrive early
Car #26..'97 SVX Silver (120k and climbing)
previous SVXi:
Car #24..'94 SVX Ebony 216k (sold)
car #18..'97 SVX LSI "Ebby" Pearl 175k (sold)
car #19..'97 SVX LSI Brilliant Red 103k (sold)
car #14..'92 SVX Claret LS-L Touring (sold)
car #13..'94 SVX Laguna Blue LS (sold)
Old 10-14-2006, 10:10 PM
There is a silicone gel called Sil-Glide. It is available at NAPA and Auto Zone. Just squeeze it from the tube and rub a small amount onto the rubber weatherstripping. it dries and leaves a slick, non-stick coating.
I have been using it for years and never had a sticking problem.
Old 10-15-2006, 01:24 PM
It's Just Eric's Avatar
Missing in action
Dont forget to hit the winter mode switch. Wont help your doors much but itll sae you money on wiper blades
R.I.P Cool Signature.
