Old 08-15-2010, 10:31 AM
Re: Powder Coating SVX Rims
The flush-fit valve stems won't fit because of the angled hole in the curved surface of the rim.
Instead I ordered a set of Gorilla Automotive VS402C Inner Mount Valve Stems
Tighten from inside the rim and short enough not to protrude too far out past the surface. Will use valve extension for inflating.
Old 08-15-2010, 02:42 PM
Originally Posted by SVXMAN2001 View Post
I am looking into powder coating my svx's rims, after 13 years their showing their age! Is there a specific color code for the 1992 rim colors. I know there is a difference in color between the older and newer svxes. Has anyone had this done before? Experiences?
In answer to one part of your question, if there is a colour code for any of the colours that are painted on the rims we have never discovered it. Not to my knowledge anyway.
John and I did a lot of work listing all the various colour codes both for USA cars and indeed for all colours listed in all markets. Nowhere in the Subaru available information is there a code supplied for the rim colours.
If you want to use the darker colour as on the 92 rims for accuracy and veracity then I think the only way to get this is to use a colour spectrum analyser which will give a good paint mix.
Personally I agree with what the boys are saying here. The later brighter silver totally lifts the look of the car. The darker silver on the 92's is a dull affair.
Old 08-16-2010, 07:47 PM
I picked up my refinished wheels from Transwheel this afternoon. They were personally brought out to me by the plant manager.
My jaw dropped when I saw them and I was momentarily speechless! All I can say is WOW!!!
I thought my wheels were perfect when they were first done back in 2002, but these are far beyond perfect. I think powdercoating technology has come a long way in eight years.
Not only is the application of the finish flawless , very shiny and deep, they took a spectrum scan of my filled and refinished center caps and tweaked the color formula ever so slightly to get a better match between the powdercoated finish and my existing acrylic lacquer-finished center caps. I could not be more pleased.
They reminded me that the lifetime warranty started all over again. They also assured me that these wheels would never come back to them for finish problems.
I will probably get the tires mounted on Wednesday Getting the valve stems tomorrow). Photos are useless as no photo would do them justice and they look better than any of the photos I already have. They have to be seen in person. Also the removal of the "stamp" and the "L" is subtle, yet noticeable to anyone familiar with these wheels; just a smooth surface all around.
Maintenance is only hot soapy water and a strong stream of water. If they ever get really dirty, they endorse only one cleaner: P21S.
This is a pH controlled, non-acid, non-lye based formula guaranteed not to attack any type of road wheel, braking system or other automotive surface. I have been using this for years.
Old 08-17-2010, 07:39 AM
I found this thin-walled 19mm socket for protecting our wheels and lugs. I was turned onto these by Transwheel.
They are usually only available in complete sets. Inexpensive protection to prevent scratching.
Click HERE
Old 08-17-2010, 01:48 PM
I think I know where my Prodrives are going next!
Old 08-17-2010, 02:19 PM
John, you must know someone at transwheel cause I had a horrible experience and they refused to paint my centercaps. Bringing out your wheels to you personally? I wish, I had all to do to get someone to open the door (2 p.m. in the afternoon btw and I had already called ahead of time notifying them of me dropping them off). Quality was ok, but sadly my experience with their customer service dept was far from satisfying. Regret ever going there actually.
Old 08-20-2010, 10:42 AM
Just finished putting them back on...
Old 08-20-2010, 10:53 AM
John, you must know someone at Transwheel cause I had a horrible experience and they refused to paint my centercaps. Bringing out your wheels to you personally? I wish, I had all to do to get someone to open the door (2 p.m. in the afternoon btw and I had already called ahead of time notifying them of me dropping them off). Quality was ok, but sadly my experience with their customer service dept was far from satisfying. Regret ever going there actually.
I am quite shocked. When were they done and at what facility? What was your specific complaint about the quality of the refinishing?
As far as center caps go, they want $50.00 each to refinish them (They charged me $100 to do all 4 back in 2002. They were already sanded and primed and ready to shoot.
If it was at the Williamsport facility, you need to contact the Plant Manager, Jane Dobrzanski at 301-223-4855 ext. 32 or send her an email at JDobrzanski@lkqcorp.com
Give me a call and let's talk 410-746-6770.
Old 08-20-2010, 02:02 PM
processengr's Avatar
Thumbs up Re: Powder Coating SVX Rims
Awesome finish on those wheels John!! Question on the chrome valve stems- do you have to use extension to fill?
Cheers! Gordon
1992 Ebony 251k 444 SOLD
1999 Silver SLK230 134k SOLD
1997 Green Outback 137k SOLD
2013 Honda Accord I4 SOLD
2015 Subaru Crosstrek 30k
2018 Tesla M3 30k
Old 08-20-2010, 03:19 PM
I decided against the screw-in short valve stems that needed an extension. If the valve started to leak, I could not tighten it from the front; I would have to take off the tire.
Instead I used regular rubber pull through valve stems. I slid rubber grommets over the stem and down to be flush with the hole in the rim. That way the valve stem does not flex and cause possible contact with the rim.
Old 08-20-2010, 04:10 PM
Are those chrome sleeves over the valve stem? Do they interfere with tire pressure gauges or air chucks?
Cheers! Gordon
2018 Tesla M3 30k
Old 08-20-2010, 05:59 PM
Not at all. The chrome caps thread onto the valve all the way to the sleeve. Taking off the cap you have the same amount of threaded metal showing as if you had just rubber.
Old 08-25-2010, 05:31 PM
newsvx's Avatar
newsvx newsvx is offline
Send a message via Yahoo to newsvx
Beautiful wheels, John!! They look great!!
Good seeing you today!! Time for a FALL meet down here in Shenandoah Valley!!
Harry
newsvx
1992 SVX LSL, #1215
1997 SVX LSi, #370
"I live with fear every day. Sometimes she lets me go racing."
"Getting Older and Slower"
Locker: http://www.subaru-svx.net/photos/user.php?newsvx
Old 08-25-2010, 06:54 PM
Good idea! Maybe we can get Ron and Cheryl to show up. Maybe Rufus too.
Old 08-26-2010, 02:24 AM
My92SVX's Avatar
My92SVX My92SVX is offline
My92SVX
Alcyone Silver Contributor
Talking Re: Powder Coating SVX Rims
Hey!!! Don't forget me!!!
2006 Ford F-150 SuperCrew XLT 4X4 Lariat Med. Wedgwood Blue/purchased with 7 miles
2000 Dodge Neon ES Cranberry Pearl/purchased with 5 miles
1998 Ford Explorer Sport Red/Gray/purchased with 44K miles
1993 Subaru SVX LSL Barcelona Anniversary #99/purchased with 82K miles *** 89K miles as of 07/2012
1992 Subaru SVX LSL Pearl/Black #7200/purchased with 72K miles *** 101K as of 7/2012
1992 Subaru SVX LSL Ebony Pearl/purchased with 88K miles *** SOLD***
