Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Engine Management
Old 05-31-2005, 04:55 PM
KCROGUEDOG
af ratio quick ?
what legacy fpr can we use on the svx? part # if possible or year and exact model and price? and is it a tough install any mods or changes? and last i read the maf on our car maxs at 5600rpm or so what would be a good upgrade a wrx one maybe on off a z or some other sports car? i read the wide band o2 thread and im very curious about these mods for a little more power and proformance.
Old 06-01-2005, 12:46 AM
mbtoloczko's Avatar
sans SVX
The Impreza RS fpr part number is in my locker.
Mychailo
Visit my locker
Old 06-01-2005, 11:45 PM
KCROGUEDOG
keep it alive people.
Old 06-02-2005, 12:44 AM
mbtoloczko's Avatar
sans SVX
It takes about 20 min to install. The hardest part is getting the fuel lines to come loose. Once those break loose, its 5 min of work.
Mychailo
Visit my locker
Old 06-02-2005, 08:25 AM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
white grease on the o-ring, make sure not to pinch the o-ring when installing the FPR. A little white grease on the fuel fitting will allow the fuel line to slip on easier (fuel injection line is a lot stiffer than regular fuel line...)
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 06-02-2005, 09:20 AM
KCROGUEDOG
i know the filter change was a pain.
Old 06-02-2005, 09:21 AM
KCROGUEDOG
any thing on the maf ?
