Old 03-30-2005, 02:50 PM
any tips/how-to's on fuel injector replacement?
......before i go diving in
also, about how much am i looking to spend on a set?
thanks!
1987 928 S4 (Black) SOLD!
1997 SVX LSi (Ebony) SOLD!
2013 G37xS (Obsidian Black)
Old 03-30-2005, 02:59 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Alan,
The consensus appears to be "grab them with a pair of bent nosed vice grips - gently - and twist and lift" to remove them. Personally, I'm working on a mini wheel puller design to remove them....
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 03-30-2005, 03:08 PM
Originally Posted by SVXRide
Alan,
-Bill
i haven't been under the hood lately - does the fuel rail have to be removed? it can't be THAT easy?!?!?
Old 03-30-2005, 04:03 PM
gl1674 gl1674 is offline
No, do not remove the fuel rail - it's not going to help.
It's twist and pull, but it's not that easy, requires a bit of determination.
Old 03-30-2005, 04:45 PM
just took a look and saw the little covers with the two bolts. i thought it was going to involve removing all sorts of crap. doesn't look too bad.
Old 03-30-2005, 04:54 PM
immortal_suby's Avatar
Thread Killah
Just unplug them, remove the 2 screws and cap, and twist them out. If they are hard to pull out then twist the plug part toward the front of the engine and very carefully pry them out with a large flat bladed screwdriver between the fuel rail and the plastic plug part.
Removing the whole fuel rail is pretty easy too, and then you can push them out from the bottom side if they are really stuck. Just be careful when you take out the 2 bolts that hold the fuel rail down - there are small spacers in there that will fall down into never-never land if you don't catch them.
Locker Link
2015 BRZ Limited 6MT
Old 03-30-2005, 05:52 PM
Electrophil's Avatar
Electrophil Electrophil is offline
Which manual is "that" in??
Alan,
-Bill
I removed two yesterday in this very same way, but I wrapped the jaws in a towel, then gripped it. Twist and pull... worked like a charm, and no damage.
Robert
Is Bush in jail yet? (Looks frantically at watch, then back up) How about now? Now? Come onnnnnn...... Someone freeze me until January, this wait is killing me.
Update: 09 January, and still not in jail! Wassup??
1992 Teal LS-L - 160k (Now new and improved with perfect paint!)
Old 03-30-2005, 07:33 PM
thanks, guys. one more question - when buying new injectors, do the O-rings come with them, or do i need to go buy some more? i have some that are fuel-resistant material, but i'll need more if they aren't included.
