Old 03-22-2005, 06:34 AM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
Fading brake performance?
When my car is cold, the brakes work awesome. The pedal is very sensitive and the car stops easily. When the car is fully warmed up after about 10 minutes the pedal feels harder and I have to push harder for the car to stop the same way.
What could cause this problem?
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 03-22-2005, 07:26 AM
n00b on demand's Avatar
You might need to get your brakes bled. My brakes are the same exact way when warmed up...i feel like i have to press them in so much to get a little response but when the car is cold they work like their supposed too. This was the case even when i got my pads changed in october.
Old 03-22-2005, 10:03 AM
AFBeefcake's Avatar
Subaru Swapper
What color is your brake fluid? Mite be time to change it all.
2005 Legacy GT
My WRX's Cardomain Page
Old 03-22-2005, 11:53 AM
Tim's Avatar
Tim Tim is offline
The brake fluid is yellow, I had it bled last summer when I took my car to svxpert (mike) for the 100k tuneup.
I changed the pads 2 years ago and I've only put on about 20,000 miles on them. Never changed the rotors, though I am this summer because they are starting to warp and vibrate.
Maybe I should add more fluid? It seems to be about an inch below the full line but an inch above the low fluid line.
Tim
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 03-22-2005, 12:27 PM
AFBeefcake's Avatar
Subaru Swapper
brake fluid should be clear.
The yellow is from oxidation of the fluid.
2005 Legacy GT
Old 03-22-2005, 12:59 PM
It shouldn't be that bad unless the fluid is brown.
Old 03-22-2005, 01:12 PM
Yea you hit the bullseye....my fluid is brown....ill change it out this weekend.
Old 03-22-2005, 07:20 PM
thundering02's Avatar
Giong back to the beaters...
My car is the exact oposite the only change for me is slotted front rotors(w/semi-metalic pads)
89 240sx se Black~185k R.I.P.
85 Toyota pickup ~205k R.I.P.
Old 03-22-2005, 11:52 PM
Hohopirates's Avatar
Hohopirates Hohopirates is offline
Lines
Sometimes a brake hose could be going bad and swelling when pressure is applied, I don't know if that could be the problem with the hot/cold issue though. A possibility thats an easy check anyway.
Steve
It's not a car..it's a boat!!
Old 03-23-2005, 07:59 AM
The brake fluid is yellow...
the first two are your problem, the oil should be changed and the discs also...
and don't add up brake oil, because as soon as you change your pads, it will be back to its normal level
