Old 03-10-2005, 05:42 AM
mhl0125 mhl0125 is offline
Send a message via AIM to mhl0125 Send a message via Yahoo to mhl0125
Tcu
Would anyone know if the TCU from a 1995 SVX is interchangeable with one from a 1994 SVX?
Michael
1994 Barcelona Red SVX-LSI
Two-owner:169K
1995 Emerald Green SVX L AWD
#80 - Custom intake w/cone filter
99K with killer stereo system
2002 Acura MDX-Touring Edition w/navigation
2008 Toyota Prius
1987 Mercedes Benz 560SL
Old 03-10-2005, 07:40 AM
one way to find out...
It should plug in the same even though they are different part numbers.
I've run my 92 engine with a 95 ECU if that matters.
Old 03-10-2005, 08:23 AM
Aredubjay's Avatar
Rat Fink Member ~:o)
Part number is 31711 for a '94 AWD and 31711 for a '95 AWD, so, they should be the same.
Randy Johnson
Mike Davis -- at Reading VI
Old 03-10-2005, 08:25 AM
mbtoloczko's Avatar
sans SVX
It will work.
Mychailo
Visit my locker
Old 03-11-2005, 10:09 AM
That's correct, however, the last 3 digits of the part number are different between the 2 years.
