Old 03-09-2005, 12:22 PM
MNYPNNY's Avatar
MNYPNNY MNYPNNY is offline
FKA....thndrmtn92svx
Alcyone Silver Contributor
Send a message via AIM to MNYPNNY Send a message via Yahoo to MNYPNNY
Question WRX stereo swap?
Question #1 -- Does anyone know if the dual din stock stereo out of a 2002 WRX will work for an SVX? I mainly want to know if it fits and if it will allow the antenna to remain down when the cd player or cassette is used.
Question #2 -- Awhile back I saw some mention of the wheel bearings out of the new WRXs working in SVXs. Is this true?
~~Michelle
'92 LS-L - copper - 190K miles
'94 LS-L - pearlie - 92K miles
*still have '92 parts*
Old 03-09-2005, 02:37 PM
Mike should know the answer to #1 and as for #2 - nope. I've heard that 2005 STi bearings work though.
Old 03-09-2005, 03:21 PM
MNYPNNY's Avatar
You're right, I think it was STi... thanks.
~~Michelle
Old 03-09-2005, 03:58 PM
SVXer95 SVXer95 is offline
Word to Yo Motha
WRX radio will fit. You will need a reverse connector from SVXdc. I just recently put in a double din six disc changer from an 05 wrx. There was no need for cutting in the back as some others have mentioned. A bit of cutting was needed to get the black plastic piece that covers the inside of the door to go back on. I believe there are pics of the finished prodcut in my locker. none of the install though. If you do a search, there are several threads on the topic. The 05 looks great, esp. with my grey 'L' dash. The silver color is very nice.
Collin
1995 L AWD
Locker
1987 Porsche 944 turbo
Old 03-10-2005, 09:01 PM
ssnsltd's Avatar
ssnsltd ssnsltd is offline
That's gona leave a mark.
are they stronger thn the origional SVX bearings?
David
96LSi 102k Laguna Blue
95 LS-L AWD, Safety package, 140k Polo Green
the Chick Magnet:
91 Justy GL EFI 4x4 154k (new motor @120k)
90 Yamaha V-Max
82 Yamaha XJ650LJ Turbo
My Diver Propulsion vehicle:
88 Jeep Cherokee 160k
"U-sta-have"
88 XT6 AWD Pearl,
86 XT Lt Blue,
85 XT AWD/4x4 Turbo Space Blue
Old 03-11-2005, 09:19 AM
Old Fogey
It'll fit....but
Just FYI you will lose the diversity tuning via the 2 antennae, connecting up only one of them, the mast I would assume. The '02 WRX changer I used worked nicely, but I did have to trim some of the cage at the rear to allow access to the antenna plug IIRC, as well as some added depth. The antenna will stay down if you initially use the CD function, but going from Radio to CD it will remain extended until power is removed. I purchased both reverse wiring plugs from svxdc so it was strictly plug-n-play. The inside cover "liner" does have to be "customized" to clear the knobs. I've been very satisfied with the changer, pics of the install in my locker.
Glenn
Old 03-12-2005, 12:28 AM
SVXdc's Avatar
SVXdc SVXdc is offline
Radio wiring harness guru
Yes, the motorized antenna is the better one to use on radios that have only one antenna input.
Bizarre. By "removed" do you mean using the power 'switch' on the radio or turning off via the ignition key?
For this mod, you want a 'forward' SVX plug (to connect to the car) and a reverse WRX plug (to connect to the WRX radio). See my post in the "For Sale" forum.
David C.
Old 03-12-2005, 10:23 AM
Old Fogey
Thanks for the added clarity about the plugs required David. Use of your plugs made the job MUCH easier. For the sake of additional clarity, the deck, when the radio function is selected, will extend the antenna, leaving it up when the CD or Cassette functions are selected. In some ways this makes good sense, reducing the number of up/down cycles. So, yep. I meant whenever the deck is switched off, by either the ignition or the deck power switch.
Glenn
Old 03-12-2005, 10:33 AM
SubaSteevo's Avatar
No longer blue member
Glenn
I don't have the WRX changer, but I'd much rather have the mast go down when the CD is selected. I rarely use the radio, so what's the point of having the mast up?
-Steve
01' MSM Lexus IS300
Old 03-12-2005, 12:19 PM
Nemesis Destiny's Avatar
Nemesis Destiny Nemesis Destiny is offline
6MT STi-ified, now with R180!
Send a message via ICQ to Nemesis Destiny Send a message via MSN to Nemesis Destiny
Last summer I bought the conversion kit from SVXdc and a WRX 6 disc changer from another member and installed it. The antenna does in fact raise ONLY when the radio is on, and switching to cassette or CD will lower it. When RojoRocket said theirs did not function this way, that was why SVXdc said it was "bizarre" because it's supposed to lower anytime you're not using the AM/FM tuner.
For the record, the radio cage does need to be modified (very easy), and there is a strut inside the dash that needs to be cut, bent, or otherwise modified or the front of the radio will not sit "right". Though, it's barely noticeable, and I've been too lazy to rip it all apart and bent the strut so it fits better. I think there are pics in my locker. Oh, and the knobs on the WRX radio interfere with the door for the radio compartment (another easy fix).
1992 LS-L Touring, Liquid Silver w/ Black, 110k mi. "Alice." Rebuilt title. Mods: WRX 6-CD changer, 17x8" Motegi LC-12 (16.5lbs), PWR rad, Perrin LCP, JDM v.8 6MT + R180, Koni + Ground Control (325f/280r), Earthworm Bushings. Awaiting resto.
1994 LSI The legendary "Shotgun Slade" 110k mi and still going strong!
2005 Outback XT Limited 5MT, Obsidian Black Pearl, 211k km, daily driver.
1999 Mazda MX5 base 5MT, Twilight Blue Metallic, 152k km. "Twilight Sparkle" Summer daily driver!
2007 Honda CR-V, some awful shade of light green *yawn*
1992 LS-L Touring, Ebony Mica, 176k kms. Parts car. SCRAPPED.
1992 LS-L, Dark Teal, 367k km. "Wintergreen" the winter beater.*SCRAPPED due to rust*
Old 03-15-2005, 11:07 AM
Word to Yo Motha
My mast stays down when cd is selected. 2005 WRX radio.
Collin
1995 L AWD
Locker
Old 03-16-2005, 03:39 PM
Say, I get tons of spam emails that claim to fix that.
Old 05-22-2005, 08:24 PM
svxxx26's Avatar
svxxx26 svxxx26 is offline
Headed to Texas...
WOW..
Thanks for the wealth of info from everyone!
svxdc, I'll be emailing you for the connectors!
Jerry
2005 Baja Turbo
2008 Ford Crown Victoria Police Interceptor
jnj7707@yahoo.com
Old 05-23-2005, 07:51 PM
svxash's Avatar
svxash svxash is offline
Here's a link to when I did mine. Also the antenna only goes up when the radio is on. When switching from radio to CD it goes down.
http://www.subaru-svx.net/forum/showthread.php?t=20238
Old 05-24-2005, 12:38 AM
Old Fogey
I stand corrected. So does mine.
Glenn
