Old 03-07-2005, 11:25 AM
mbtoloczko's Avatar
sans SVX
drop 30+ lbs for $160
Been thinking about installing an Optima battery. I keep hearing claims that the batteries are lightweight. I checked it out, and it seems to be all hype. The OEM battery weighs around 40-45 lbs. All the Optimas weigh about 38 lbs. I guess its a few lbs, but not what I was expecting. So, I did a little more research, and found this battery:
<http://www.brailleauto.com/ProductCa...=2&idproduct=1>
weight is 11.5 lbs which gives a ~30 lbs weight savings. Now that's some real weight savings. Hoping to install one sometime this summer. Chike, when are you getting one? :-)))
BTW, and the thing is tiny. 6"L x3.5"W x6"T. Compare that with a normal battery: 9"x7"x9".
Mychailo
Visit my locker
Old 03-07-2005, 11:33 AM
wawazat??'s Avatar
Yeah, I'm still around
Question
For us winter climate folks (that haven't followed the link ) what is the CCA rating?
Todd
Down to none
Old 03-07-2005, 12:26 PM
lhopp77's Avatar
lhopp77 lhopp77 is offline
Old Timer (age that is)
Winter People?
Guess it would be used like a set of winter wheels/tires for winter only?? This battery would only be used for track day, maybe?? Stock sized heavy battery with loads of CCA for normal everyday driving??
Lee
SVXx2
92 SVX LS-L Silver
96 SVX LSi Red
92 SVX LS Pearl (Parts)
01 F150 4X4 Red
FREEDOM IS NOT FREE
Old 03-07-2005, 12:50 PM
mbtoloczko's Avatar
sans SVX
Todd
360 CCA. Not so great. You could use two Braille's in parallel to get 720 CCA and still save 20 lbs! :-))) Maybe your lighter wallet would partially offset the 11.5 lb increase from the second battery. :-))
Mychailo
Visit my locker
Old 03-07-2005, 12:51 PM
Mr. Pockets's Avatar
Moderator
Wow. And I thought most companies built entirely on their marketing went belly-up with the tech companies.
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 03-07-2005, 02:37 PM
Phast SVX's Avatar
BOOOOOOOOOOOOOOOOOST
that kind of power wont crank up my antena feb
~Phil
Old 03-07-2005, 03:53 PM
CigarJohnny's Avatar
But imagine the horsepower gains from switching to a lighter battery! LOL
Johnny (referencing another thread)
Old 03-07-2005, 08:44 PM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
Interesting battery Mychailo. Tom (svxfiles) was telling me about it on the phone tonight. I'll look into it, but with only 360 CCA, I'd need a bit more for VA winters - however, this would make a pretty sweet summer battery...
-Chike
2006 Steel Gray WRX TR (sold)
Old 03-07-2005, 09:05 PM
alltrac alltrac is offline
I don't mean to threadjack but hawker is the best.
Odyssey combines in one box the characteristics of two batteries. It can deep cycle as well as provide serious cranking power. These batteries are capable of providing engine cranking pulses of 1700a for 5 sec as well as 400 charge/discharge cycles to 100% depth of discharge (DOD). A typical battery can do one or the other, but not both. With other batteries such as Optima, you must decide between a deep cycle or a high power starting battery, but Odyssey does both.
The cranking power of a Odyssey battery is double to triple that of equally sized conventional batteries, even at low temperatures.
Also with simple constant voltage charging, there is no limitation on the inrush current. This means you can charge your battery with as many amps as your charger, alternator, stator, or generator can put out as long as it doesn't exceed 15 volts. Lead acid, gel cell, and other AGM batteries can only accept 10amps per hour during charge.
Which Odyssey battery do you need? You have three basic things to consider:
1. The amount of power and reserve needed.
2. The amount of space available.
3. The method of securing the battery.
PC680MJT
Small 680 cranking amp battery with metal jacket and SAE automotive terminals.
Also available without the metal jacket for low temperature applications.
Battery measures 3.11" wide x 7.27" long x 6.67" tall with the metal jacket and weighs 15.4 pounds.
Excellent starting battery where high reserve capacity is not required.
Great lightweight racing battery for shedding extra pounds.
Can be mounted upright or flat.
PC925MJT and PC925LMJT
Medium duty 925 cranking amp battery with metal jacket and SAE automotive terminals. A step up from the 680 that provides higher cranking power and a larger reserve capacity.
Battery measures 7.05" wide x 6.64" long x 6.08" tall and weighs 26 pounds.
Can be easily mounted on it's edge to accommodate side post applications.
Side mount will accommodate BCI group 21, 26, 50, 58, 64 and others
Mounted on it's edge will fit the OEM Honda Civic tray.
The PC925LMJT has the positive terminal on the left.
I found prices for $109 on the net. I stand by my claim for hawker as they offer mil spec batteries. Even boosthead recommends them.
Victor
