Somethings not right - what the heck is it?
So - I noticed the other day that there's this terrifying sound coming from somewhere. It's a rythmic "swooshing" that I only hear at say 40+MPH ....one thing weird about it is that I only hear the noise when I'm on the gas.
If I let off the gas and coast at any speed the noise goes away. Also if I through it in Nuetral and rev it, there's no noise. So it can't be something in the wheel area or engine or else my guess would be that i would hear it all the time regardless if I was accelerating. This leads me to believe that it's something in the drivetrain ................but no clue what it could be. Diff, trans, axels?? Everything seems to be working fine - no driveability issues, but the noise is there when I have to make the car go. any ideas? I'm sure it can't be good.
Mike - Proud owner of a Pearl 92 SVX LS-L 5MT with 78k miles and climbing 5-Speed Status: DONE! Lambo Door Status: On hold but will be a success 04 WRX 5MT, STi Short Throw Shifter, Group N tranny mounts, AZA Z-2 18x7.5 Rims, slotted/cross drilled rotors, stainless steel lines, 35/20% window tint, ecu bead crush, power mode button; 7" In-dash touch screen LCD, mobile computer, voice recognition, alpine PXA-H701 DSP, 2 JBL amps, focal speakers all around, 5 farad cap, and fiberglassed subs in the trunk. The Mobile Computer Interface - featuring the SVX | My Locker | My Secret Stash |
Assuming the rhythm is speed sensitive I would believe it's going to be a u-joint on the driveshaft or possibly a diff.
So, if you're at 40+mph and you let off the gas there's no noise? Can you get someone else to ride along with you and try to isolate where the sound is coming from while you drive? I'd go with David's suggestions, except your post said you only hear it while you accelerate.....
-Bill
I think it only does it when the torque converter is locked ....i think - i need to get a second opinion
My 94 did that before it's diff died. My 92 is doing it now. I am going to have it checked out -- perhaps tomorrow. Will post notes.
Lwin M. Maung (Member # 147) Current SVX: • NONE Previous SVXes: •1994 LE Barcelona Red 107k • 1992 LS-L Pearl White 143k • 1994 LSi Bordeaux Pearl 220k • 1992 LS-L Ebony Pearl 184k • 1992 LS-L Liquid Silver 145k • 1992 LS-L Liquid Silver 102k • 1992 LS-L Ebony Pearl 123k Other current cars:•2001 Jeep Grand Cherokee Black If at first you don't succeed, CHEAT!
You're having dif trouble too?
(Mine didnt have any symptoms before it suddenly ground itself to bits) |
Not sure yet. Just a whine when you step on the gas.
did you think about the EXHAUST ? you say when you press on the gas, the sound appears (pressure on the exhaust) and when you release (no pressure anymore) the sound disappears. if it were the diff, the sound must always exist, either running idle on the highway or pressing the gas... but I guess this is an exhaust trick...
Sounds like the diff. mine did the same thing drain the fluid and look for chunks of metal. I think it only makes the noise when you are on the gas is because you are putting pressure on the faces of the gears that move you forward (the ones that are damaged). When you are in neutral or coasting there is no force being applied. I hope that was an ok explanation. Expect the noise to get worse then really bad you have a day or 2. I hope this is good news, 5-speed or 4.11.
"The things you own end up owning you. It's only after you lose everything that you're free to do anything." 92 Pearl White Ls-l (138k) Euro Headlights & Blinkers, 97 Grill, Euro Tail Lights, SS Brake Lines, Stebro Exhaust, Slotted Rotors, Classic Registration 96 Legacy Outback (206k) 5-speed 2.2 Lightweight Crank Pulley, Group N Trans & Motor Mounts SOLD Wanted: Steering Wheel |
okay - so this must be serious ....kinda figured that. I should be mad, but I think this came at a good time - except for the fact I need a beater car while my SVX gets frankensteined.
So - I'm planning on doing the WRX 5spd swap, but what do I do for diff gears? I hear all about replacing them but isn't that only for the rear diff? I guess I'll be doing some searching on the forum. Weird thing is, I know the noise was present on my way back to school - I've driven at least 150 miles with the noise (highway). But who knows how long it's been doing it, because I can only hear it when the heats off and the stereos off - which is a rarity. Thanks for the help.
My 94 lasted me a good 2 months before it died. So you have some time. if it helps
so something new - I came to a stop and the car stalled out. Then it ALMOST did it again ................nice felt as though the trans was still in gear ......like coming to a stop in a manual trans car without pressing the clutch.
Thats not good. On the other hand, I am working on my AIPC project again.
Your car stalling when coming to a stop sounds as though either your Duty solenoid B is malfunctioning and the torque converter is not unlocking or else your engine temp sensor is malfunctioning and your engine/tranny are in limp mode.
