Old 12-21-2004, 10:01 PM
Bxsvx Bxsvx is offline
How fast is fast?
Send a message via AIM to Bxsvx
How to remove wheel studs?
Hey, anyone have detailed instructions on removing the front studs and also the rears? I also need to know what tools to use. Thanks
Old 12-22-2004, 06:01 AM
96svxer
On my Hondas I've alwas beat on them with a hammer Seems to work fine, pop right out. Your results may differ though
Old 12-22-2004, 06:13 AM
michael's Avatar
michael michael is offline
What Potholes ???
If you have the rotor off, get some old lug nuts and screw them about half way on and pound the sh!t out of them with a small sledge hammer. It may help to saturate the studs in PB Blaster the night before and some heat couldn't hurt like propane. After you get all of the studs loose the ABS tone ring will be holding them from falling out. They are hex bolts which are probably rusty so you may have to drill them out, good luck it's a pain in the a$$ job.
P.S. be careful with the tone ring, they break easily.
P.S.S. I don't know anything about the rears, sorry
Wanted: Steering Wheel
Old 12-22-2004, 07:19 AM
wawazat??'s Avatar
Yeah, I'm still around
Wow, you guys like using the speed wrench, aka BFH on these things, eh?
Todd
Down to none
Old 12-22-2004, 07:22 AM
SVXer95 SVXer95 is offline
Word to Yo Motha
Todd
BFH is always fun, but I prefer using an air hammer....
Why do you need to take them out? In all my experiences, I have only replaced ones that have comes loose. Are the threads all messed up or something?
Collin
1995 L AWD
Locker
1987 Porsche 944 turbo
Old 12-22-2004, 08:12 AM
michael's Avatar
What Potholes ???
The transmission shop stripped mine and denied it
Old 12-22-2004, 08:21 AM
mohrds's Avatar
mohrds mohrds is offline
Fight Eminent Domain Abuse!
Todd
1994 LSi (4/93)
1969 Mustang GT Convertible
1970 Mustang Convertible
2000 Ford Excursion
Old 12-22-2004, 07:12 PM
SEA Sleeper
Why diddn't he just hand thread it a few times first?
While bleeding my brakes last week I found one of the lugs had been cross-threaded on undoubtedly w/ an impact gun. I spent 5 min twisting untill the stud finally snapped and hit the garage floor like an emptied shell casing. I allmost feel like driving to ID and throwing it through the front window of the shop that rotated the tires just before I bought her... but I like to keep my concience clear. Lucky them.
Pulp fiction reference "oh, what I'd give to catch that mother****er doin it"
Anyways, I bought the car used so I guess I should expect small things like this.
I plan on driving around w/ a 4 lug wheel untill June when I'm taking Driveline technology in school. I figure I might as well do it right AND get credit for it if possible.
BXSVX, I suggest you take it to a flat rate shop and sip coffee while you listen to the obscenities eminating from the shop. Might be more entertaining than prime time television.
Old 12-22-2004, 08:46 PM
How fast is fast?
sea:lol. man if they curse at my car, im going to punch the tech's
svxer95:yea, all the threads are gone and chunks missing.
Micheal, 96 svxer, you guys recommend beating my daughter? I can never hurt her
Old 12-23-2004, 06:23 AM
96svxer
Hey it could have been worse, I could have said use a sledgehammer? She should be thankful
Old 12-23-2004, 08:11 AM
How fast is fast?
lol, yea a hammer is a couple of steps up from the sledgehammer lol
Old 12-23-2004, 01:04 PM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
Before you become too convinced that it someone's fault you might consider that chrome lugnuts have a tendency to bind up on lug studs. What happens is the chrome on the lugnut threads eventually flakes and lodges in the threads and the only way to remove it is to twist the stud in half. You'd be doing yourself a favor to take the remaining lugnuts and tap the open end of them on a clean piece of paper to see how much crap comes out of them. Also, any nut(s) you can't spin completely on to the stud is suspect.
Why is everyone so quick to blame the tech? Damn! It's not like this stuff can't happen for any other reason (like a 12 year old car with a gazillion miles on it, for starters.) Besides, who here is perfect? I can't count how many times I've rec'd the wrong order at a drive-up, bank errors, etc. Sorry, but too many people have jumped on this bandwagon of bs.
Old 12-23-2004, 01:09 PM
michael's Avatar
What Potholes ???
I would have given them the benefit of the doubt if the didn't scratch my rims, loose my engine cover clips, forget to put my dipsticks in and bend my antenna.
Old 12-24-2004, 10:24 AM
How fast is fast?
Damn that sucks, I am definitely not going there!
Old 12-28-2004, 07:14 PM
svx_commuter's Avatar
If you can get the stud out by beating on it with a hammer than that is great. If the hub is still on the SVX and the bearings are in place, excessive force could damage the bearings. I have a picture in my locker showing a large C-clamp I use. The pic is for a 97 Impeza and I have used the same for the SVX.
I have noticed that when the SVX wheel comes off the rim will often drop onto the studs and this leaves aluminum in the threads of the studs. A quick wipe will remove it before installing the nuts.
I like to check all the lug nuts after I get new tires or work done on the cars. One time a stud was messed up and most times the nuts are to tight. Now I don't use the shop that stripped the stud.
SuperbVehicleXtraordinary
Proud sponsor of a 1992 SVX.
