REAR BEARING.......yikes!
I told you it was getting worse....quickly...
Check this out! .....
Jim 1995 Laguna Blue SVX AWD L - 240K (daily driver) - "ReBuILT" used engine at 236K miles (6/13) 2013 Veloster Red - Driver Now??Dropsprings [1/2" rear, 1" front] with Koni Strut Inserts> Magnaflow Exhaust System> ECUTune Stage 1av1 Upgrade (from 1v4)> ECUTune TCU MOD> Aluminum Crankshaft Pulley> Stainless Brake Lines> Phenolic Spacers> Perforated Brake Rotors (dint like, OEM now)> SmallCar Shift Kit (resting since TCU MOD)> 7-Position Ground System> High-Pressure Fuel Pressure Regulator (resting)> ATF Cooler & Campaign Filter> Yellow Polish Polyurethane Bushings> Pioneer Double-DIN Stereo with JL AUDIO Speakers> Driveshaft Rebuilt with C-Clip U-Joints> 15 Min MOD> 20 Min MOD .. . (2011) Valentine One Radar Detector with Remote Display - ucan'tseeme! |
It's like trying to drive a nail with the hammer sitting on the nailhead. Not much happens until a little clearance occurs and allows some 'swing' room, when that happens the nail starts moving quickly.
Looks like lube failure, what condition were the seals in? Oops - strike that, they had to be destroyed after that much heat and motion.
Why did you have to mention that, Beav!
Why did you have to remind me.....(that I forgot to order the seals with the bearings.....and didn't notice til I had the hub out!)
ALRIGHT!...YES!....I REPLACED THE OLD SEALS!.........now are you happy.....go ahead and YELL AT ME! (SENILE OLD FART, etc.) Well, they looked OK....and I baby'd them out ....but,of course, they must be damaged (not like we both thot tho!)... I used Redline red high-temp grease.....maybe I didn't get a good thorough press of grease....or maybe the degreaser I used to get the shipping grease off last time (water-based) interfered with the new grease at that time...? BUT...this bearing worked fine for about two years ....then suddenly (and rapidly, as you can see) degraded starting about September this year... SOUNDS LIKE A NEW CAR NOW!
guys, a curious (and for some stupid) question, how you know your bearings need replacement? does it show any physical symptoms? a certain sound? ... help ?
sound?
A GROWLING SOUND....usually from the rear bearings...
Mine started sounding like a tank badly in need of repair... You need a ($200) HubTamer tool if you do it yourself.
Re: sound?
1993 25th Anniversary Edition # 156 of 301 ~ 121, 488 miles ( SOLD TO svxfiles 8/6/06) 2006 Subaru Impreza 2.5i....5spd - My daily driver 2006 Subaru Legacy 2.5i -7k miles..Mom's daily driver 2,543 Member of the SVX World Network |
It can also sound like you've got snow tires on the back....
Best way to be sure is to get the car up on a rack and use a stethescope to listen to the bearings - this way you'll know which one is actually making the noise. -Bill
awww crap...I made the snow tire comparison last night but now you get credit for it I accidentally posted it in the thread about steel braided brake lines. Whoops! Anyway...I think that's the best comparison...a bad wheel bearing sounds like you've got some knobby 44" tires off a big ol' truck. One day it will just be a fait roar, but as time passes it will get louder and louder. It should also sound louder in the cabin if you put the rear seat down. Finally, from my experience, it's louder at certain speeds than others, and really gets loud at <10mph under braking.
Time for my very own long list of mods: 92 SVX LS-L - Ebony Pearl - 2002 WRX 5MT trans w/STi gearset (rebuilt & installed myself ) - BMW E46 HID retrofit - Kenwood Headunit - Phoenix Gold 75x4 RMS amp - Alpine Type R 6.5" front components - Alpine Type R 6x9 3way rear speakers - 18"x9" Rota G-Force wheels w/225/40ZR18 Toyo T1R's - Mychailo's custom springs - Urethane front & rear sway bar bushings - KC exhaust (2.5" dual magnaflow) - Escaine seat swap - Removed Spoiler I don't care if Subaru says it's STI...it will always be STi to me |
Does anyone in California know where I could rent a Hubtamer? Does Kragen, Pep Boys, Auto Zone, or any other big chain rent one? If not an auto parts place, is there a chain machine rental place that rents one? (I'm in Orange County, if anyone knows of a specific place here.)
'92 Touring Ebony |
RENT HubTamer.....?
Wish you were closer.....I'd be glad to let you borrow mine.....I use it once every 2 or 3 years! BUT...Fresno is too far away.....and this thing is HEAVY!....TOO HEAVY TO SHIP!
Hopefully, someone from the network will pop up down there in the L.A. area....? Good Luck! P.S. I didn't find anyone renting here....that's why I bought... off eBay...
Jim 1995 Laguna Blue SVX AWD L - 240K (daily driver) - "ReBuILT" used engine at 236K miles (6/13) 2013 Veloster Red - Driver Now??Dropsprings [1/2" rear, 1" front] with Koni Strut Inserts> Magnaflow Exhaust System> ECUTune Stage 1av1 Upgrade (from 1v4)> ECUTune TCU MOD> Aluminum Crankshaft Pulley> Stainless Brake Lines> Phenolic Spacers> Perforated Brake Rotors (dint like, OEM now)> SmallCar Shift Kit (resting since TCU MOD)> 7-Position Ground System> High-Pressure Fuel Pressure Regulator (resting)> ATF Cooler & Campaign Filter> Yellow Polish Polyurethane Bushings> Pioneer Double-DIN Stereo with JL AUDIO Speakers> Driveshaft Rebuilt with C-Clip U-Joints> 15 Min MOD> 20 Min MOD .. . (2011) Valentine One Radar Detector with Remote Display - ucan'tseeme! Last edited by James Scott; 12-23-2004 at 01:23 AM. |
I recently started hearing a clicking noise in my wheels and just as i thought, it was the wheel bearings. The shop wants $600 to do it but my dad insists that its easy to do and i can get the parts for about $60, but he is in North Carolina right now. How hard is it to do by yourself (given you have all the right tools)?
Teal 92 SVX LS L with 103k Engine: Stage 1, 3 in filter with heat sheild, underdrive pulley, NOS fogger system (75 shot)to be installed soon Sound:1 10" infinity with 230 continuous watt Dual amp (we have small trunks) |
dcb |
NOT too Hard!.....
I'm a "shade-tree mechanic".....I pick others brains, then do (basically) what they convince me is best.....I'm very mechanically inclined...But, a little (more like ALOT) like the "absent-minded professor......SOOOOOOOOOOOOooooooooooooooooo.....
I'd say .....medium difficulty....BUT...like anything...First time's alot tougher than 2nd or 3rd times...... For example, I believe the HubTamer says to press out outer bearing race from upright...toward the center of the car....? ....BUT....in fact....IT NEEDS TO BE PRESSED OUT TOWARD THE WHEEL SIDE OF THE UPRIGHT [IN THE DIRECTION OF THE BEARING SNAP RING RETAINER].... This might be a no brainer for most.....but I'm the type that might do what the directions indicated....AND RUIN THE UPRIGHT...OR?]
Thread Tools | |
Display Modes | |
