Old 12-22-2004, 12:11 PM
whoa thats a ton of info comming back to this thread! Anyways, it has been said that the SVX pistons are indeed slightly larger (Bore) than the Ej22t. Thats what i understand, SO why is should we not slightly overbore the EG33 to handle custom pistons that would go ahead and run a lower C/R? Why is everyone biting for the Ej22t? If you are buiolding an engine to run boost, you are going to spend a good deal of money, why chop yourself off at the knees and buy cheaper pistons? Your best bet, if boosting high levels, is to have custom pistons made for you. Not cheap but very effective and will prob cause less problems down the road.
Old 12-22-2004, 12:18 PM
SVXer95 SVXer95 is offline
Word to Yo Motha
Bingo.
I've said it before. Doing modifications of this type, you can't go cheap. Spend the money, do it right. Custom pistons aren't that expensive anyway.
Collin
1995 L AWD
Locker
1987 Porsche 944 turbo
Old 12-22-2004, 02:26 PM
mohrds's Avatar
mohrds mohrds is offline
Fight Eminent Domain Abuse!
For myself, its more of an intellectual exercise. Obviously custom will be the way to go, but there may be bolt on equipment.
For instance, with Ford, if you take a 351 Windsor block and adapt on 351 Cleveland heads, you can get much more performance than either engine modded up on its own.
Doug
1994 LSi (4/93)
1969 Mustang GT Convertible
1970 Mustang Convertible
2000 Ford Excursion
Old 12-22-2004, 03:40 PM
Piston facts.
Wow lot of confusion. The facts as I see them are, the EJ 2.2lt turbo pistons will fit the EG3.3 bore, they are the same bore size, the wrist pin height and offset will be the same, They have the same selective fit as the SVX.
The piston crown height is what controls the compression ratio, they did not change the combustion chamber volume on the EJ 2.2 when they built the turbo, they just fitted pistons with a lower cut out in the top of the piston. These pistons lowered the EJ 2.2 's, 9.4:1 ratio to the turbo's 8:1, a drop of 1.4. If these pistons were fitted to the EG 3.3, the compression ratio would drop from 10:1 to 8.6:1.
I know that the SVX pistons have a raised lump, of about 1 to 1.5 mm on them, instead of a cutout that the EJ2.2 has(according to Wayne), so our cylinder head volume may be larger (may be due to bigger valves?), but the Turbos pistons will still drop the ratio by 1.4:1 at least.
Old 12-22-2004, 05:22 PM
but with all pistons in the engine being different like that thread suggests, won't that throw a wrench in things?
Old 12-22-2004, 05:40 PM
SEA Sleeper
Re: Piston facts.
This is music to my ears. Thanks for the info Harvey!
Old 12-22-2004, 07:29 PM
The pistons used in Subarus are all selective fit. There are 3 different sizes, they varie by 0.0005". This is no problem, it is to ensure a much better fit than the US engines uses. The sizes of the cylinders is stamped od the top of the engine block, along with the sizes of the crankshaft bearings. that are also selective fit.
So when you are getting the EJ 2.2 turbo pistons, you order the A,B or C size, to suit the, A,B, or C bore size that your particular engine has. Not a problem.
Old 12-23-2004, 07:23 AM
I am still not convinced, how does 9.69 cm bore pistons fit 9.99 cm ??? that's a difference of 0.3 cm... furthermore our engines are used, don't expect to see an exact 9.99 cm bore chamber in the block, itis rather 10 or10.05.....
Old 12-23-2004, 01:49 PM
drivemusicnow's Avatar
Poor College Racer
... none of the subies are 9.999 they both are 9.69..
Greg
97 Red SVX LSi clean
96 Black SVX LSi beater
90 Red Eclipse GSX track ho
99 Ford F250 work horse
Old 12-23-2004, 02:34 PM
lee lee is offline
I've attached a file that shows some of the specs...looks to me like the 92 turbo pistons would work, but then again I've never seen inside a Subaru engine so anything I think is highly suspect.
Old 12-23-2004, 05:01 PM
Yes mate it does look like they will do the job. Though I would like to see the top of the 2.2 and 2.2T pistons to be sure. I have seen the top of the SVX pistons, and been told that the raised section is about 1.5 mm high. I would think the lower 9.4:1 comp 2.2 pistons would have a flat top, or a shallow cut-out in them, and the turbo pistons would have a deeper cut-out in them.
If someone with a fast connection could search for pics of the top of both 2.2 & 2.2T pistons, it would help in solving this quest.
Old 12-24-2004, 01:16 AM
are you sure??? because I heard it was rather 9.999..... not 9.69. If this is the case, I would bore the chamber to put the 9.96 cm pistons... better i think
Old 12-24-2004, 09:51 AM
what is the stroke on the 2.2l motors? I am not sure if this popped up sooner (thats a whole lot of technical stuff) so if anyone could answer me that would be great. In eefect if the stroke for the 2.2Lt is too short, it could infact raise the C/R right? I would imagine it is a relative so just another wrench to throw into things
Old 12-24-2004, 12:06 PM
Myetball's Avatar
Myetball Myetball is offline
Mr. Inappropriate
This is just some random thinking on my part but it seems Subaru likes to keep things simple. If you cut two cylinders off the 2.2L motor you end up with 1.1L. With 1.1L/2cyl. you end up with 3.3L with six cylinders.
Much cheaper to build a 6 cyl motor based on an existing 4 cyl motor. Granted there are many differences, but exactly how many sililarities are there?
Old 12-24-2004, 12:25 PM
lee lee is offline
what is the stroke on the 2.2l motors? ...snip...
see attached
