Old 12-09-2004, 12:37 PM
vwmrbill11
transfer case, clutches etc.
I just put a tube of Mr. Shudder(their is also a product called Shudder Fix) in my auto transmission fluid and the shudder and binding is gone. I drove around 40 miles in town this morning, making sharp u turns and no shudder or binding. Great stuff. Got it at a transmission specialty place. Bill
Old 12-09-2004, 01:43 PM
red95svx
Re: transfer case, clutches etc.
That's great. Now as long as Mr. Shudder replaces your worn clutches while he's in there you'll be all set
Old 12-09-2004, 02:35 PM
Mr. Pockets's Avatar
Moderator
Re: Re: transfer case, clutches etc.
I understand that a bad duty solenoid c will cause binding, but will a worn clutch do the same? My understanding was that a worn clutch will just slip or not engage at all. My wife's old Legacy used to spin the front wheels considerably before the rears engaged with a *thunk*.
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 12-09-2004, 02:37 PM
Moderator
Originally posted by possumfat9
must the transmission have to be removed to replace clutch? Thanks
To replace the transfer clutch? No. The extension housing comes off without removing the transmission from the car.
But you do have to support the transmission, because the rear mount bolts to the extension housing.
2005 Outback
END OF LINE
Old 12-10-2004, 09:10 AM
red95svx
Re: Re: Re: transfer case, clutches etc.
By far most of the binding we see is caused by the clutch itself, not the solenoid.
Old 12-10-2004, 10:09 AM
Moderator
Re: Re: Re: Re: transfer case, clutches etc.
Can you explain to me why this is?
2005 Outback
END OF LINE
Old 12-10-2004, 10:13 AM
red95svx
Re: Re: Re: Re: Re: transfer case, clutches etc.
I will gladly ask one of the techs. I'll report my findings after lunch. MMMMmmmmmm.....lunch!!
Old 12-10-2004, 01:02 PM
red95svx
Ok, the official response:
"When the transfer clutch assembly wears, the plates make grooves on the drum. This causes binding."
Old 12-10-2004, 01:13 PM
Moderator
Well, that's very...interesting. If you can get a more detailed answer than that, I'd appreciate it. If not, that's okay.
I'm just curious why the plates wear grooves into the drum and whether the drum then has to be replaced or repaired.
It just doesn't make any sense to me. A bad solenoid causing excess pressure on the clutch would mean that the clutch plates' teeth would be binding on the drum and possibly cutting groozes into it, but I don't understand how a clutch that is simply worn could cause these grooves.
Thanks for taking the time to ask, though. I do appreciate it.
2005 Outback
END OF LINE
Old 12-10-2004, 01:29 PM
red95svx
Sorry, I'm a transmission idiot. I wish I could add to that explaination but I can't. The guys are pretty busy and that's the best I could get at the moment
Old 12-11-2004, 03:57 PM
Skinwrangler
Duty C replacement, need housing gasket?
I have been driving (without binding) in front wheel drive mode and bought a Duty C solenoid. Reading this post I wondered, do I need a gasket for the extension housing?
My tranny has about 20K and began binding on slow corners, popped in the fuse and no binding.
Jerry
Old 12-11-2004, 04:42 PM
For the $2.48 it costs on subaruparts.com I would be changing the gasket while I'm in there!
Old 12-11-2004, 05:44 PM
Skinwrangler
Extension gasket part number?
I looked on the Subaru parts site and they did not have the exploded digram up of the parts, anyone happen to know what the part number is?
Many thanks.
Jerry
Has anyone posted a blow-by-blow of the Duty C repacement experience?
Old 12-11-2004, 05:53 PM
Are you referring to part #7 here:
http://www.subaruparts.com/diag/?mod...category=175-A
Old 12-11-2004, 06:17 PM
Moderator
David's right - the gasket is so cheap you might as well get one just to have it. There's a chance you're going to rip it when you remove the extension housing.
2005 Outback
END OF LINE
