Old 12-05-2004, 01:54 AM
TonyShaleUK
Dashboard lights
Christmas came early - dashboard lights up like a Christmas tree after the car is started. Drove home fine last night, now when the car is started, the following lights stay on..
ATF temp
Steering
Ign
Stop lights
ABS
Any ideas what the cause is?
Thanks
Old 12-05-2004, 04:17 AM
TonyShaleUK
Tried to start the car this morning - very sluggish. Switched off, tried again, just the solenoid rapping. Yo!
Hooked another battery up, exactly the same. No fault codes...
Old 12-05-2004, 05:04 AM
TonyShaleUK
Ok, had battery checked - completely dead. New one fitted, started strongly. Lights still on tho! Cancelled codes just in case but no change.
Help!!
Old 12-05-2004, 05:17 AM
gsodonis's Avatar
gsodonis gsodonis is offline
Alternator
Sounds like your alternator. Do a search on alternators and you'll read plenty of posts that sound like yours. Testing the alternator at a parts store doesn't always work as many members have had theirs test OK but turn out bad. A bad alternator would explain the bad battery. If you don't get this repaired, your next battery will be soon dead too.
Old 12-05-2004, 06:51 AM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
It's a result of the way Subaru wired the alternator (battery) warning light. The rectifier and regulator need to be replaced, or you can replace the entire alternator. If you're handy and have a soldering iron replacing the parts are (is?) relatively simple.
Old 12-05-2004, 06:59 AM
TonyShaleUK
Thanks both.
Had the belts replaced a couple of weeks ago, so thought that it might be that. No such luck, adjusted the tension.
When idling, the battery is only seeing 12.07 V.
Anyone have part numbers for the bits?
Old 12-05-2004, 03:41 PM
Beav's Avatar
Not as old as Randy
http://www.subaru-svx.net/forum/show...ght=alternator
Old 12-08-2004, 09:06 AM
TonyShaleUK
Thanks Beav,
My reconditioner has never heard of these numbers, altho' I have got them off the website that you supplied. There is a distributor in Germany, so I may well go direct to them to get them supplied.
