Old 12-10-2004, 08:19 AM
Originally posted by SVXer95
White smoke = coolant. Blue Smoke = oil.
Definitely the wrong oil for that car.....
sorry over here we call it white smoke, it's the proper oil engine at that time, because all the bearings inside are f*cked up!!! it is burning 1 oil quart per 9 days !!!
Old 12-10-2004, 08:36 AM
SVXer95 SVXer95 is offline
Word to Yo Motha
Originally posted by SilverSpear
no I am not mistaken !!!! look :
<An oil with too low a viscosity can shear and lose film strength at high temperatures> ----> this is why I use 10W-60 in the Summer, because 10 becomes 0 and 60 becomes 30
AND
<An oil with too high a viscosity may not pump to the proper parts at low temperatures and the film may tear at high rpm.>
-----> this is why I use 0 in winter because of low temperature!!!
'The wide viscosity range oils, in general, are more prone to viscosity and thermal breakdown due to the high polymer content'
= 10W60 is bad.
10 does not become 0 and 60 does not become 30. The oil has a SAE rating of 10 when cold, and 60 when at operating temps(hot).
The ratings take into account temperature. That is one of the reasons they give a rating instead of direct centistokes. It is a range! Your oil does not turn into a 0W30 when it gets warm.
Collin
1995 L AWD
Locker
1987 Porsche 944 turbo
Old 12-10-2004, 08:39 AM
Word to Yo Motha
I didn't think it got that cold in Lebanon during the winter unless you are up in the mountains. You shouldn't need to change to a thinner starting weight oil unless the temperatures are VERY low.
Collin
1995 L AWD
Locker
Old 12-10-2004, 09:24 AM
drivemusicnow's Avatar
Poor College Racer
yeah.. the only "change" that happens is between the two numbers that are on the bottle. 0w50 goes from a 0 weight cold, to a 50 weight hot... thats it.. no other random numbers...
Greg
97 Red SVX LSi clean
96 Black SVX LSi beater
90 Red Eclipse GSX track ho
99 Ford F250 work horse
Old 12-13-2004, 06:33 AM
= 10W60 is bad.
ok so what do you suggest? 0W-30, 0W-40 or 0W-50,
the 0 is accounted for, but as a temperature in summer, we are like miami or south california (or Texas if you want), which is the better oil weight? I don't wanna change the oil weight either in summer or winter...
