Old 11-23-2004, 09:06 AM
pavanbabut's Avatar
Question Help needed in running wires from trunk to battery
Hi,
I have ran wires from the trunk to the dashboard through the center console. i am not having any idea on how to run those wires to the battery from there so that i can make a connection to the battery +ve.
thts the only remainin work in installing my audio system. Please gimme some suggestions on running them upto battery as soon as possible.
Pavan.
Old 11-23-2004, 09:09 AM
SubaSteevo's Avatar
No longer blue member
Near the gas petal there is a large grommet with a large bundle of wires going through the firewall. Pop that out and run it through there.
P.S. It's probably easier to run the wire from the battery to the trunk, not trunk to battery.
-Steve
01' MSM Lexus IS300
Old 11-23-2004, 09:43 AM
pavanbabut's Avatar
thanks for ur advice... i will try to do it today and let u know....
Pavan.
Old 11-23-2004, 03:47 PM
pavanbabut's Avatar
Hi BurgundtBeast,
I am not able to identify that firewall which u r talkin about. Can u tell me in detail how i have to run my wires to the battery please. From the engine side i am able to see 2-4 outlets of wires with out any opeing in them. But really i am not getting from where i have to run the wires, thts the only work remaining.
Anyone plz. help me on this issue, this is my first attempt in doin work on my own...
Thanks,
Pavan.
Old 11-23-2004, 04:18 PM
thundering02's Avatar
Giong back to the beaters...
I ran mine down the driver side fender well just behind the small panel and under the driver door sill there is a hole right next to the battery so it comes out pretty clean.
89 240sx se Black~185k R.I.P.
85 Toyota pickup ~205k R.I.P.
Old 11-23-2004, 04:31 PM
SubaSteevo's Avatar
Originally posted by pavanbabut
Hi BurgundtBeast,
Thanks,
Pavan.
There is one large group of wires held in place by pretty much a large rubber stopper that you can pop out.
-Steve
01' MSM Lexus IS300
Old 11-23-2004, 07:00 PM
pavanbabut's Avatar
if u don't mind and if u r having time can u please sanp off a picture of that place both from inside and outisde and post it. I also want to kow whether I ahve to remove anythig for doin this or just i can push the wire through it.
Thanks,
Pavan.
Old 11-23-2004, 09:13 PM
SubaSteevo's Avatar
Sorry, dont have my camera. If you take a pic of the firewall below the brake master cylinder I'll point it out to you.
-Steve
01' MSM Lexus IS300
Old 11-23-2004, 11:37 PM
UberRoo's Avatar
UberRoo UberRoo is offline
SVX Appeal
I ran mine through the passenger's side. There is a huge grommet on the passenger's side firewall (shared by the air conditioning lines, I think.) Get an pointy stick, tape some rope to it, soap it up (to make it slippery,) and stick it through the grommet. It'll come out just behind the heater box. Tie or tape the rope to your wires and give a good tug.
Also, I recommend running the wires down the side of the car, not the center. Either will work, but the side seems to work best.
UberLocker
Old 11-24-2004, 01:59 AM
pavanbabut's Avatar
hmm... i too didn't have a camera, i will borrow from my friend and take a pic of it....
Thanks,
Pavan.
pavanbabut's Avatar
thanks for ur advice,
i will try urs too and let u know...
thanks,
Pavan.
Old 11-24-2004, 11:17 AM
Here's the best pic I have from my existing catalog of pics:
Old 11-24-2004, 02:19 PM
pavanbabut's Avatar
thanks a lot David.. I got an idea on seeing this i will try it today....
Pavan.
Old 11-24-2004, 03:00 PM
pavanbabut's Avatar
Hi david,
i figured out those outlets but mine are all sealed...should i have push through them and see them from inside or is there any other easy way to do this....
Pavan.
Old 11-24-2004, 03:31 PM
It does pop out. You could try drilling a hole through it. When I had my stereo installed they shoved the wire through the same hole as the throttle cable. (BAD)
Mine now runs through this large hole along with all the other wires. It also runs down the center console. My RCA cables run along the driver's door sill to my amps in the back.
