Old 11-20-2004, 11:47 AM
Knightwulf's Avatar
Knightwulf Knightwulf is offline
Showing my car ignorance... (Brake Fluid?)
Alright... So my brake light keeps going on and off at random times, so I've assumed I'm low on fluid...
Now.. I've found what I believe to be the area where I add more, it's about an inch above the minimum level... However... Is that tiny reservoir really where I add the fluid?
'97 Ebony Pearl LSi (Luna) 111,000 - Sold to 1986nate
'09 Obsidian Black Pearl Legacy GT Ltd. (Raven) 028,000
Old 11-20-2004, 12:04 PM
SubaSteevo's Avatar
No longer blue member
Yup, usually the BRAKE(!) light is triggered by the ABS sensors. Theres an ECU under the passenger seat that blinks a light for the code.
-Steve
01' MSM Lexus IS300
Old 11-20-2004, 12:22 PM
UberRoo's Avatar
UberRoo UberRoo is offline
SVX Appeal
The brake light will also go off if there are loose connections. If topping off the fluid doesn't help, check all the brake lamps. Just because the bulbs work doesn't mean it's not a bad connection. Removing the bulbs and checking for corrosion is a good step to take if you're still having problems. Just removing them and reinserting will often fix it. In my car, the plug that goes onto the brake light switch on the pedal was loose. That was a head-scratcher.
UberLocker
Old 11-20-2004, 12:26 PM
Knightwulf's Avatar
Okay.. Next question... I have no idea what was in it before.. If I use a synthetic that "exceeds D.O.T. 3 & 4 standards" and mix it with what's already in there...
Is this a bad thing?
Old 11-20-2004, 01:22 PM
thundering02's Avatar
Giong back to the beaters...
I know that you can't mix dot 3 and dot 5 as they are two totaly different stuffs and will do damage to the system if its not clean of the other. so yeah probably not the best of ideas.
89 240sx se Black~185k R.I.P.
85 Toyota pickup ~205k R.I.P.
Old 11-20-2004, 08:51 PM
While DOT 3 and 4 are compatible with each other, they cannot be mixed with DOT 5 (silicone) brake fluid.
However, the answer lies in DOT 5.1 Synthetic Brake Fluid
It is an extra long life, 100% synthetic (non-silicone) fluid used for hydraulically actuated-brake and clutch systems. (It is based on Polyglycol chemistry).
DOT 5.1 non-silicone base brake fluid is a suitable upgrade from DOT 3 or DOT 4. Fluidity specially designed for anti-locking brake systems (ABS). It is fully compatible and miscible with conventional brake fluids. This version also has extra anti- corrosion additives that protect ferrous, white and yellow metal brake system components.
Typical service life up to 10 years for DOT 5.1 Extra Long Life Formula.
For a lot more information, check out the Syn-Lube website at http://www.synlube.com/brake.htm or search Google for DOT 5.1 brake fluid for other options.
Cost of the Synlube extra long life fluid is about $18.00 for a half liter bottle.
On a related note, for those who haven't seen it, here is the link to my simplified explanation of wet and dry boiling points of brake fluid.
http://www.subaru-svx.net/forum/show...boiling+points
Old 11-20-2004, 11:24 PM
SSSVX's Avatar
SSSVX SSSVX is offline
One teal and One yellow
thanks for john's always quality and knowledgeable post....
my brake(!) light sometimes came on and off depending on the temp outside. if it's cold, the brake(!) is surely on even i released the e-brake. if it's warm outside, the brake(!) light will be disappeared. i think i read the brake fluid sensor is quite sensitive?
hmm, after i topped up my brake fluid to the max level, no more brake(!) light comes on anymore....
-SSSVX
92 LS-L TEAL since Aug '01
92 LS-L YELLOW since Mar '05
Old 11-22-2004, 06:34 AM
dcarrb dcarrb is offline
Actually, a problem with the bulbs (faulty connection or burnout) will illuminate the STOP LAMP indicator, not the BRAKE light. The latter lights only when the brake fluid level is low, or when the parking brake is set.
Someone mentioned that an ABS problem may trigger the BRAKE light. Not positive about this, but I think not. That's the job of the ABS warning light.
Top-off the master cylinder (and as it was low, watch the level in coming days and keep an eye out for a leak), perhaps disconnect and re-connect the leads to the sensor at the base of the master cylinder to ensure good contact, and chances are good the problem will be solved.
dcb
Old 11-22-2004, 03:27 PM
Thanks for the clarification Darrell. You're completely correct!
Old 11-23-2004, 01:24 PM
red95svx
dcb
You are right.
As far as ABS is concerned, the ABS sensors trigger the ABS light, not the BRAKE light.
He may also want to check the condition of his brake pads. Low pads will cause a larger drop in brake fluid than normal causing a BRAKE light to come on when the brakes are used.
Old 11-23-2004, 01:49 PM
Originally posted by red95svx
You are right.
Subaru experience to thank for that. It's cool that the car lets you know when a brake light bulb has blown.
Do any makes other than Subaru have a burned-out-brake-light-bulb indicator?
dcb
Old 11-23-2004, 10:29 PM
UberRoo's Avatar
SVX Appeal
My bad. Those are different lights. Good call dcarrb.
ABS, Brake, and Stop Lamp; three brake-related indicators. The engine doesn't even have that many - just Check Engine and Oil. There really should be a temp light too, but maybe the Check Engine light performs that function. The gauge just doesn't jump out at you. Too hard to miss.
I guess being able to stop is pretty important though.
Yes. Ford has them. Some of their Crown Victoria's come with that option. When your brake lights are out, these reeeeeeeally bright lights come on, but they're hidden in the rear view mirror.
UberLocker
