Old 11-19-2004, 12:13 AM
Re: solution
Originally posted by svxpert
ok, here is my solution. i had wired up the wires so the "N" is lit on the dash. this worked, but often the car would just die as the rpm's would die after a 2-3 rpm load. i then switched the wires to lite up the "D" on the dash and have yet to have the car die. its been 6 months so far. the wires are under the hood, going into the firewall, your just going to have to try different ones until you find the ones that lite up the "D". please let me know if this works for anyone else.
any pics for the whole process??
Old 11-19-2004, 05:39 AM
No lights at all on mine, and I've never had an issue with it dieing...might try to adjust your TPS a little to increase the idle speed...
Old 11-19-2004, 11:26 AM
That only works for about 3 starts then the ECU compensates for the TPS adjustment.
Old 03-25-2005, 09:07 AM
Im going to be trying to find these wires today but I've never had a light lit up on my dash and i have the nss switch wired up from the old tranny harness...Just curious if anyone had luck with this
Old 03-25-2005, 10:57 AM
mbtoloczko's Avatar
sans SVX
If you look at the ECU pinout, the only pins on the ECU related to the 4eat shifter position are pins B60-9 and B60-10 which are parking and neutral position inputs, respectively. Thus, the ECU only knows if the tranny is either in Neutral or Park. In a standard 5MT install, these pins become ungrounded and automatically hold a voltage. So, by default, the ECU thinks the car is in D, 1, 2, or 3. This can be verified by looking at the ECU and TCU diagrams. If you compare the ECU and TCU wiring diagrams, you'll find that causing the "D" light to illuminate on the dash has no effect on either the Park pin or the Neutral pin. The difference that svxcess noticed wasn't due to enabling the "D" light but due to ungrounding the Neutral pin on the ECU.
Mychailo
Visit my locker
Old 03-25-2005, 11:48 AM
It doesn't help the stalling for me but it does correct the high idle when cold and it also disables my cruise. I'm going to wire a switch in my interior to toggle this setting.
Old 03-25-2005, 06:23 PM
The Lights in the instrument cluster are wired to the shifter, not the NSS...that's why they never light up, the shifter is unplugged.
