Old 11-16-2004, 11:02 AM
ilsegretosvx
other Subaru auto trannys for SVX
Does anyone know if the newer 3.0 trannys will work on our SVXs. Im just looking into options and would like a newer one.
Old 11-16-2004, 01:51 PM
lee lee is offline
I believe it would require some electronic interfacing as the TCU is probably different to handle the definitely different transmission internals, i.e., no band, etc.
Old 11-16-2004, 08:37 PM
bolting it up would prob not be a problem but you would have to completly rewire your tcu. I already went through this. Its better just to get a plug and play trans.
Old 11-16-2004, 09:09 PM
ilsegretosvx
rewiring is not a prob. I might do the newer TCU and rewire from the ECU if possible, heck if I could find a way I would put a 05 outback 3.0 tranny in with the steering wheel controls...heheheheh
Old 11-17-2004, 04:56 AM
LarryIII LarryIII is offline
The Outback XT /Legacy GT with the 4 cyl., 2.5L turbo engine has the 4EAT control pushbuttons on the steering wheel.
The Outback 3.0R with the 6 cyl., 3.0L engine does NOT have the 4EAT control pushbuttons on the steering wheel. The steering wheel pushbuttons control the radio in this model.
I have driven both cars.
The 4EAT tranny in both of these models is NOT a direct bolt up.
An Adadaptor must be fabricated to bolt this tranny housing to the SVX engine. Also, this tranny must be shortened because our engine is longer then either the 4 cyl., or new 6 cyl. Suby engines.
That's just the mechanical side. I don't know what it will take electronically.
Larry III & The Beautiful Naviguesser
'19 Tungsten Pearl Outback 3.6R Ltd...."AISHA"
'08 Harvest Gold Outback 3.0L. L. L. Bean...."AIJOU"
'07 Gray Diamond Pearl Outback XT Ltd..."AH SO"
'05 White Pearl & Silver BAJA Turbo..."AH HA"
'97 Bordeaux Pearl SVX LSi..."SUBYDOO"
'94 White Pearl SVX LSi..."PEARLY"
'92 White Pearl SVX LSL w/touring pkg..."SVXY"
'92 Teal SVX LSL w/touring pkg..."ALCYONE"
'96 Polo Green LSi ... "MIDORI"
'00 Black Dodge VIPER RT-10... "VINNIE"
Engineers do it with precision.
English teachers are novel lovers.
Home: larrysingeriii@comcast.net
SVX FEVER, CATCH IT AT A MEET NEAR YOU !!
Old 11-17-2004, 05:16 AM
change the engine/tranny system, the new 3.0L + tranny
Old 11-17-2004, 11:18 AM
once you get an idea, you just can't get off it can you?
Old 11-17-2004, 12:05 PM
ilsegretosvx
Well its not a bad idea considering that the engine is 250hp stock and I really like the steering controls on the wheel (the Outback LTD does have the steering controls) it would make a very unique SVX
Old 11-17-2004, 12:47 PM
good luck. the wiring systems are totally different and well just about everything would be different. it would take a total remapping of the svx and for what? you just need a new trans. Is it really worht it?
Old 11-17-2004, 01:02 PM
ilsegretosvx
same reason people are puting the 2.0t WRX motors into older Imprezas and Legacys, it can be done. I look at it this way, I could buy what to replace the SVX.......nothing, so I modify it the way I see fit. I dont feel like spending 70k+ for a new car (2 dr AWD).
Old 11-17-2004, 03:04 PM
you said ur trans was blown not trans and engine. why would you waiste all that time and money for an extra 20hp? it just doesn't make sense, and also, the 3.0 is an interferance engine which ours is non.
Old 11-18-2004, 12:47 AM
I am thick headed, even though 2 yrs ago my family and friends convinced me not to make the fiberglass kit, I stubbornly did it
Old 11-18-2004, 03:30 AM
svxpert svxpert is offline
tranny
<<The Outback XT /Legacy GT with the 4 cyl., 2.5L turbo engine has the 4EAT control pushbuttons on the steering wheel.>>
the turbo legacy has a 5 speed auto tranny.
Old 11-18-2004, 12:57 PM
i did not mean that offensively, determination is a good thing, just make sure it will be the best thing to do before deciding to do it thats all.
Old 11-18-2004, 04:52 PM
Bobb Bobb is offline
Engineering
Hey Larrylll, Your post sounded like a mechanical engineer talking. Yes, really. Take care, BOBB
