Old 11-12-2004, 07:22 AM
SVX JAZZ's Avatar
SVX JAZZ SVX JAZZ is offline
Tired
Hard start and other stuff fixed.
Praise report…
When my car would sit for an hour or so after driving, it would have a hard time “firing up”. It acted as if it was flooded. I then began to have problems with it backfiring, rough idle, and the feeling as if it were running on 5 cylinders (intermittent). Meanwhile my auto seatbelt went south.
I took it to several places in the area and found a guy that felt confident he could fix it. Turned out that 4 of the 6 injectors were leaking and one of the coil packs was not putting out full strength.
I wasn’t sure about him at first but he did a great job. Runs like a new car. It must have been sick for a while and not getting full horsepower. I feel like its gain about 40hp.
The fix… 6 new injectors and one new coil. A little over $600 for the injectors and $80 for the coil pack. He charged around $480. All this isn’t cheap but I don’t plan on doing anything major for a while and I had been saving up.
The seatbelt is another issue and that will be another post.
This morning was great. Listening to Pat Metheney and driving my “Bat Car”.
Old 11-12-2004, 07:52 PM
Treppiede Treppiede is offline
Re: Hard start and other stuff fixed.
I am happy your SVX is running good now, however if I well understood this guy charged you $480 to install injectors and replace the coil pack? Somebody correct me if I am wrong, but an injector replacement job shouldn't take more than one or two hours at the most, I am not sure about the coil pack. Assuming your mechanic charges the average $70 per hour rate, it looks like it took him almost seven hours to complete the job. That sounds like a looong time, are you sure you haven't paid for his lunch and smoke breaks as well?
Regards,
Walter
1995 SVX Green - now 5spd! ..::|SOLD|::..
1991 Talon TSi AWD (~400 whp pump gas)
1993 Civic CX Hatch (daily driver)
1999 Ducati 748S (built 996 engine)
Old 11-15-2004, 06:44 AM
SVX JAZZ's Avatar
Tired
He did other things
He did several other things. Serviced plugs fule filter etc... I also had him test my sensors such as crank, cam, etc and get back with me on how they read out. He made a few adjustments to the throttle body as well. Realy drives like new.
